Amsoil Bypass Oil Filters
i was thinking about getting this...
http://www.amsoil.com/products/bf.html
By-Pass Oil Filters
Engine wear is caused by dirt particles larger than 5 microns. The AMSOIL By-Pass Oil Filter removes particles as small as 1/10 of a micron, virtually eliminating engine wear. AMSOIL By-Pass Oil Filters filter all the oil in a six-quart system in about five minutes at an average engine speed equivalent to 45 mph.
has anyone else seen or used it & have any opinions/comments?
By-Pass Oil Filters
the guy i buy my amsoil from has pretty much sold me on it...i juts wanted other people's opinions.
A lot of the applications seem to be for domestic motors. Any example of 4-cylidner imports using this? or real-world pictures? (something to ask the guy you buy amsoil for).
I've looked at the same product; more so the remote bypass/full flow filter combo. It should tap in at the stock oil filter location. Mounting the remote filters would make changing the filter a piece of cake too.
"Engine wear is caused by dirt particles larger than 5 microns. The AMSOIL By-Pass Oil Filter removes particles as small as 1/10 of a micron, virtually eliminating engine wear. AMSOIL By-Pass Oil Filters filter all the oil in a six-quart system in about five minutes at an average engine speed equivalent to 45 mph."
-CRAP! ...most engine wear is caused by cold-start-up!
i remember seeing someone rig up a system that required oil pressure built up before it would allow the car to startup. Anyone else see it or have a link to it?
#1 This would only filter oil above a certain oil pressure.
#2 This would not eliminate the bypass valve in your oil filter, which could cause a potentially serious loss of oil pressure.
#3 http://www.cantonracing.com has FAR better oil solutions, including high flow spin-on oil filters without a bypass valve.
I REALLY like what I'm seeing with these filters.
http://www.cantonracing.com/tech.cfm
I'm going to try and find a little more info about them, but I may be "sold" too hah.
Trucking/shipping fleets use these filters with great success.
I would not put it on my personal vehicle. this will introduce more parts that can fail.
I think Honda did a pretty good job at designing these motors with regards to their lubricating/filtering. I will leave my setup alone.
-kenji
-kenji
Kenji-
While I appreciate the argument of less is more...the spin on filters don't look half bad. http://www.cantonracing.com/spin-on.cfm
They claim you only have to change the filter every 2 oil changes...although I kind of like the idea of having a new filter in there each time.
This looks way too complicated. Just do your oil change often and you GOOD filter. I'm planning to get Canton/Mecca remote oil filter setup.
Jay Kim
Jay Kim
holmesnmanny
Dec 10, 2009 03:14 AM
CW-ITR
Jun 18, 2004 03:57 PM
