bad idle / maintence / general? + extra info
Old Jan 20, 2003 | 09:16 AM
turbo sol's Avatar
Default bad idle / maintence / general? + extra info
well i finshed my timing belt, alternator belt, fuel filter, brake lines, valve adjustment, water pump, and clutch in the new crx i just bought. Everything seemed to go pretty good. I was goign to change out the tensioner with a z6 tensioner form a spare block i had laying around, but they are different and do not swap out. I also loosened the crannk pulley bolt a different way than normal; remove flywheel cover, put from engine brace bolt back in block, use on eof the bolts from teh header brace and tread it into the back of the flywheel(from the presseure plate bolt holes, and stick somthign between the 2.
Problems:
1. on my way to work tpday i threw a CEL. I think this is from not having the speedo cable connected (i still dont understand how that works, if soemoen has a picture of the hole it goes into that would help me.)
2. my idle seems to fluctate between 1000 rpms and 1200, it has a little surge to it. ? I bleed the coolant system but maybe i didnt get all the air out?
3. also on my way to work my clutch cable's nut, to adjust the play, backed all the way out and i lost the clutch. I retightened it but how does it stay there? I only have one nut ontop of the bracket it goes through. is that normal?
4. is it normal for the upper control arms to go bad bc it looks liek i have soem negative camber in the from (at stock ride heigth)
thanks for the help,
-s
Old Jan 20, 2003 | 10:08 AM
sporkcrx's Avatar
Default Re: bad idle / maintence / general? + extra info (turbo sol)
1. The CEL is definetly from your speedo cable if it isn't connected. It's tricky to get in. In the hole that you insert it to, there's a lil slot that you push a clip into, that holds the cable in. Feel that puppy up and you'll find it.
2. I hate idles. Anyways, mine was fluctuating between 1000 and 1500 and all it was, was the throttle body screw. Try closing it a lil (clockwise)
3. Mine did that once too, right after I installed my clutch. I adjusted it again until it felt right, and it stayed there. I think it'll pop off if it isn't adjusted to the right spot, putting too much pressure/tension on it.
Old Jan 20, 2003 | 12:29 PM
88ZCRX's Avatar
Default Re: bad idle / maintence / general? + extra info (sporkcrx)
Mine sometimes does the idle surge in the cold, I have been told by numerous ppl it is probably the idle air control valve, but I don't feel like buying a new one because it doen't last for too long.
Old Jan 20, 2003 | 05:33 PM
turbo sol's Avatar
Default Re: bad idle / maintence / general? + extra info (88ZCRX)
thanks guys i finally got the speedo cable to work. yeah hopefully that takes care of the CEL. I readjusted the clutch cable we';; see how that goes. any thoughts about bad camber on a stock suspension?
Old Jan 21, 2003 | 05:38 AM
sporkcrx's Avatar
would you happen to know how much they cost new? I might replace mine just so I can eliminate it whenever I have idle probs.
Old Jan 21, 2003 | 05:55 AM
drjondurst's Avatar
Have you tried getting an alignment?
Old Jan 21, 2003 | 09:02 AM
turbo sol's Avatar
Default Re: bad idle / maintence / general? + extra info (drjondurst)
i am goign ot get it aligned soon and see what they say, i drove to work todya no CEL!! yeah. BUT my speedo needle bounces when i stop at a stop light it does a little danc ofr a second or 2 the subsides, it seems fine when i drive as far as not jumping around only when i am stopped. any thought?S
thewrai6th
Dec 3, 2018 12:34 PM
JasonYo
Apr 3, 2010 10:32 AM
kornerk12
Apr 13, 2009 05:33 PM
Hondaisok
Sep 14, 2006 07:26 AM
ethan9273
May 6, 2003 03:31 PM
