compression check question
Old Jan 20, 2003 | 07:59 AM
Type RS's Avatar
Default compression check question
alright when you do a compression check how do you know what your compression ratio is, like 11.0:1, etc.
see i have an ITR engine with a fat gasket, make that 2 gaskets. my compression was measured at 140 in all 4 cyl. what is my compression ratio. i know i'm not running the stock 11.0:1 it should be at, but want to know where i'm at now.
Old Jan 20, 2003 | 08:47 AM
1bad-eg's Avatar
Default Re: compression check question (Type RS)
You're probably at around 9.0-1.
Old Jan 20, 2003 | 09:20 AM
texan's Avatar
You can't know for sure, because cylinder sealing affects the test numbers. What's a whole lot easier is to calculate it using your new gasket, or combined gasket thickness. How thick are the gaskets you're running now?
Old Jan 20, 2003 | 09:58 AM
Type RS's Avatar
Default Re: compression check question (texan)
the gaskets i'm running now are thick. i'm hating it so much. can't wait to go back to stock to see the real potential of my engine.
Old Jan 20, 2003 | 09:59 AM
Type RS's Avatar
Default Re: compression check question (1bad-eg)
yeah that's what i was telling everyone. but i had no clue for sure. i was just guessing.
Boostn B20
11
Nov 27, 2008 01:22 PM
High Reved Racing
Jul 14, 2008 04:37 PM
Evil_Wizard
Oct 2, 2002 12:39 AM
stretracr
May 7, 2002 12:28 PM
