what is difference between , Type A or B Pistons???? H22A
discovered my H22 has horible compression levels, and are forced to rebuild, and the Ques. of A or B came up and I had not a clue? Was looking for some advice on how to determine what I have and difference between the two? Thanks for any input..
Thank You for your input Sir.
In tern I could use the Type S pistons, but since I have a 94 H22A I woulds have to make an adjustment so my rod could accept a Full Float pin right? Not to sure on what pins come stock in mine. Thanks..
Guest
Posts: n/a
so is mine. actually i have both Helm books for the H22A. A1 and A4. Don't ask why i have both its a long story. Anyway the numbers i took from the 97+ helms. anyway Blah Blah Blah, nuff said about all that.
