how do you check for IC leaks?
I had a pressure test done on mine before it was installed.
What they did was seal one end and on the other end have a pressure gauge and air pump on the other. Then started to force air into the IC. Sure enough there was a very small leak. They got a new one, did the test in front of me and it held steady at 30psi.
I would recommend getting one done on your IC if you are not sure.
MoreCowbell
Nov 11, 2011 07:33 AM
DSF
Apr 22, 2002 03:39 AM
