Pistons poll!!!
You forgot PCT (CTR). WHY? They are cheap and they are the best OEM piston for all motor. I am running them and
them.
them.
If this is the case and you combine this with some good cams and head work you'll be making some serious power. I would check out their website some real good info.
You can buy CTR pistons new through several aftermarket companies. One that comes to mind is Options Auto Salon. I think they carry them for something like $60 bucks per piston. Also check the Best Buy section of this site.
can ctr pistons be used for daily driving?
With your B18C1 block with CTR pistons and a B16A head your compression would be in the area of 11.8:1. Why waste money on aftermarket? CTR pistons are half the cost of those other aftermarket ones. They also come with the special coating to reduce friction.
would ctr pistons work in a LS motor what would be needed for this combo? my LS is on the verge of croaking (it starts knocking at 4000 rpm) so im gonna do a rebuild on the bottom end of my next motor with pistons rings and thinner head gasket any other recmmendations?
check out this site and e-mail them for a price on the ctr pistons with rings.
http://www.alljdm.com
Colt Seavers
33
Feb 22, 2006 04:17 PM
