H22 civic withOUT EGR!?
Old Jan 19, 2003 | 11:46 PM
KStuned's Avatar
Default H22 civic withOUT EGR!?
Ok, besides a check engine light what could be a problem with running an h22 engine in a civic and NOT hooking up the EGR. I understand that what it does is recirculate exhaust gasses to be re-burnt, so I am hoping that I won't have any problems. However, my automotive instructor told me that it is possible to cause slight detonation? This is odd, he tried to explain it to me but I don't comprehend how. Is anyone running their H22 without EGR, and how long have you been running it like that? Any problems?
Old Jan 20, 2003 | 12:30 AM
KStuned's Avatar
Default Re: H22 civic withOUT EGR!? Engine theory
Do I have to worry? H22 without EGR, anyone doing this.
TTT
Old Jan 20, 2003 | 06:10 AM
Mikey3000's Avatar
Default Re: H22 civic withOUT EGR!? Engine theory (Hondaddict)
i dont have the EGR hooked up in my H22 Civic. you do get a CEL when the car is warmed up but that wont hurt anything. i would think that having the EGR hooked up and working would cause detonation not the other way around. i believe it puts exhaust gases back into your intake manifold so they can reburn most of the bad crap. that would seem bad to me as far as combustion chamber temps are concerned. i dont know if i'm accurate the way i describe how the EGR works though, *shrugs*. to answer your question, you have to worry about it failing emissions, u dont have to worry about performance loss or improper running (i.e. poor idle).
[Modified by Salvatore Leone, 10:11 AM 1/20/2003]
Old Jan 21, 2003 | 07:11 PM
StorminMatt's Avatar
Default Re: H22 civic withOUT EGR!? (Hondaddict)
Actually, the motor will run better without EGR. If you don't want a check engine light, use a JDM H22A ECU. The JDM H22A did not have EGR.
Old Jan 21, 2003 | 08:14 PM
KStuned's Avatar
Default Re: H22 civic withOUT EGR!? (StorminMatt)
well, my motor is a jdm h22 and it had EGR, so uhhh no.
Old Jan 21, 2003 | 08:44 PM
3gLudeH22A's Avatar
Yes, you can run without the egr. I have nothing hooked up to my egr..EXCEPT the plug...and it it also blocked.....so basically keep the egr plugged up and the ecu will be happy eventhough its not doing anything.
Old Jan 21, 2003 | 09:00 PM
YumVTEC's Avatar
wrong as stated, but the JDM p13 is much less sensitive to the egr not being hooked up or not functioning than the USDM p13. it will not always throw a code everytime you drive. talk to Poison about this topic. i gleaned my info from him.
Old Sep 27, 2003 | 04:20 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">Actually, the motor will run better without EGR. If you don't want a check engine light, use a JDM H22A ECU. The JDM H22A did not have EGR.</TD></TR></TABLE>false, jdm p13's did have EGR. if you dont want a code for egr use a gsr ecu with H22 maps.
Old Sep 28, 2003 | 08:00 AM
H23vtecEG's Avatar
Default Re: H22 civic withOUT EGR!? (fastwanabe)
i'm so glad i have a VX model it was allreday set up with EGR.
y dont you guys hit the junk yard and find a VX and take all the EGR vacum assembly box you need for EGR if you really want to install it
Old Sep 28, 2003 | 09:51 AM
AngryTroll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaddict &raquo;</TD></TR><TR><TD CLASS="quote">... However, my automotive instructor told me that it is possible to cause slight detonation? This is odd, he tried to explain it to me but I don't comprehend how. Is anyone running their H22 without EGR, and how long have you been running it like that? Any problems?
Yes, that is correct. Detonation may become a problem because combustion temperatures under load will increase without the EGR system working properly. This does not mean your engine will automatically ping when you do not use an EGR valve. Some engines are more or less sensitive to higher combustion temperatures. Your timing, octane of fuel and carbon deposits will obviously be a factor, too.
I would be surprised if you see any performance improvement if you do not use an EGR valve on a stock or slighty modified engine. If anything, your performance will suffer if the engine does detonate.
deucedeuceEK
Apr 26, 2006 05:56 PM
Pikachu
Nov 18, 2003 10:17 AM
