Need Help!!!!
I have a -3 plus camber
The man that aligned my car said i need to replace my upper control arm
I got a spare rex in my back-yard and decided to take it off. The only problem is that I can't take it apart. Exactly how do you?
[Modified by CrX_HF, 6:48 PM 1/19/2003]
if your gettin a whole new control arm.. you mise well use a hammer
EDIT: i get it now.. get a separator. i wouldn't recommend the fork type because they rip boots
[Modified by madeiniraq, 10:01 PM 1/19/2003]
When u use that tool it comes apart, but the bushing stays on right?
Do I need to put it back together before I use the tool?
[Modified by CrX_HF, 7:05 PM 1/19/2003]
it's all one piece the rubber is just a cover to prevent dirt from getting into the ball joint
edit: just have someone hold onto the control arm to keep it from moving around to much. also you can get a cheap spreader for like 15 bucks
[Modified by SIRX, 9:07 PM 1/19/2003]
So use that tool to keep the bushing good?
BigD+Itsuki
Jun 24, 2002 10:50 AM
