Compression check? Are my numbers good?
Old Jan 19, 2003 | 03:47 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Compression check? Are my numbers good?
Ran a compression check on my car. It currently has 56,000mi and burns oil like a freak. I got 215psi on the dot on all four cylinders. Good or bad? Thanks in advance.
Old Jan 19, 2003 | 03:48 PM
Dave-ROR's Avatar
Default Re: Compression check? Are my numbers good? (ActiveAero)
yep, 215 is fine.
Old Jan 19, 2003 | 03:50 PM
Hooch'n's Avatar
Default Re: Compression check? Are my numbers good? (FyrStarter)
The biggest concern is how close the # are to eachother!
Looks good
Old Jan 19, 2003 | 03:52 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Compression check? Are my numbers good? (Hooch at 8400-RPM)
Looks good
Well everyone was dead on the spot. I didn't block the throttle body open. Does that really matter?
Old Jan 19, 2003 | 03:54 PM
Dave-ROR's Avatar
You should redo the test with the throttle wide open. It should def hav an effect on the numbers but they'll still come out good IMO considering the 215's across the block.
Old Jan 19, 2003 | 03:55 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Will they be better or worse?
Old Jan 19, 2003 | 03:57 PM
Dave-ROR's Avatar
Dunno honestly. I've never done a compression test without the throttle being open
Like h00tch said though, as long as they aren't horribly low and don't vary much you'd good to go.
Why is it burning oil anyways? oil rings?
Old Jan 19, 2003 | 03:59 PM
Splat's Avatar
Collector-o-Guns and Drinker
How varied is bad? Neighbor's friend bought a '99 GS-R that we suspect has been ridden hard. Outsides are 210, middle two are 240.
Old Jan 19, 2003 | 04:08 PM
Dave-ROR's Avatar
Default Re: Compression check? Are my numbers good? (Splat)
I'd have to check helms, but I *THINK* it states 10% variance? maybe 15? hell maybe 20... I can't remember for sure.. sorry pat
Old Jan 19, 2003 | 04:11 PM
Hooch'n's Avatar
Think it is 10% to 15% difference if I am not to drunk!
Old Jan 19, 2003 | 05:42 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Yeah I guess so because it burns it BAD. I'm talking like 4 quarts or more between oil changes. I always keep an eye on it though and have never ran it low yet.
Old Jan 19, 2003 | 05:53 PM
cheezthis's Avatar
Not sure about the percentages...but according to my 95 helms, the maximum psi variation is 28 psi for the b18c1...with a nominal compression of 270 psi and minimum being 140. I imagine the numbers are similar to that of a b18c5.
Old Jan 19, 2003 | 06:06 PM
HXMan's Avatar
That seems like alot of oil. Perhaps it isn't rings, and maybe a problem with the PCV system, or maybe there is a leak somewhere?
Or it could be you drive your car REALLY hard.
Old Jan 19, 2003 | 06:16 PM
Nameless RB26's Avatar
Default Re: Compression check? Are my numbers good? (HXMan)
What is it supposed to be stock?
I need to test mine...
Old Jan 19, 2003 | 08:45 PM
markpaco's Avatar
Default Re: Compression check? Are my numbers good? (Nameless)
Helms says:
213 nominal
135 minimum
28 max variation
My B18C5 was 205-210 and my B18C 96 Spec was 205 across. My old B18C1 was 205 across too.
Old Jan 20, 2003 | 12:19 AM
If You Slip You Die's Avatar
yep, 215 is fine.
Old Jan 20, 2003 | 12:20 AM
TypeR 599's Avatar
Default Re: Compression check? Are my numbers good? (lilxjoker)
i got 225-235 all across
Old Jan 20, 2003 | 02:00 AM
00MRSi's Avatar
Default Re: Compression check? Are my numbers good? (TypeR 599)
Damn, that's burning mucho oil.. You using Mobil 1 synthetic? Numbers sound ok..
Old Jan 20, 2003 | 05:03 AM
Cyber ITR's Avatar
Default Re: Compression check? Are my numbers good? (00MRSi)
i need to check my 96spec itr then
Old Jan 20, 2003 | 05:23 AM
pleiades nutz's Avatar
You know I did a compression check over the weekend as well....I pulled 210 in each cyl without the throttle wide open. I have 30k on the car and I am going through a quart every 1000 miles it seems. I don't know what the problem could be but I am running rich as hell.....took the car on its first road trip and went about a 120 miles using up a little over half a tank .....I think there is some thing wrong
[Edit] Oh yeah i just have an intake, axle back and timing advanced 2.......
[Modified by oRgy, 8:25 AM 1/20/2003]
Old Jan 20, 2003 | 09:13 AM
lube's Avatar
Default Re: Compression check? Are my numbers good? (oRgy)
Is the motor supposed to be warm when you do a compression check?
Old Jan 20, 2003 | 09:46 AM
Dave-ROR's Avatar
Default Re: Compression check? Are my numbers good? (lube)
yes.
Old Jan 20, 2003 | 10:21 AM
lube's Avatar
About how warm? We just checked the compression on my buddy's jdm r motor and all the cylinders were in between 225-232. I took a temp gun and checked where the spark plugs are and it said 115degrees. Just wondering about how warm it needs to be?
Old Jan 20, 2003 | 10:22 AM
Dave-ROR's Avatar
I believe the helms states "operating temp". I usually do a comp test after driving somewhere to get something (food, beer, etc).
rmrider12522
Mar 1, 2014 08:16 AM
1992cxhatchB16A2
Oct 21, 2008 06:42 PM
anth2k4
Mar 25, 2008 06:20 PM
98prelude98
Apr 12, 2005 08:39 AM
RCautoworks
Aug 23, 2003 05:27 PM
