question on spoon tb...
Old Jan 19, 2003 | 11:00 AM
user 9782082308's Avatar
Default question on spoon tb...
I was just looking at my stock h23 tb and noticed theres not enough metal to bore it out to 70mm. How did they do it??? Do they manufacture the entire tb from scratch or does the b series have alot more metal there?
Old Jan 19, 2003 | 12:39 PM
STEALTHMODECOUPE's Avatar
Default Re: question on spoon tb... (racerx)
arent the TYPE S throttle bodies bigger than the H22's??
adaM
Old Jan 24, 2003 | 03:14 PM
Default Re: question on spoon tb... (STEALTHMODECOUPE)
Probably. I just wondered how Spoon did it.
Old Jan 24, 2003 | 03:42 PM
hanson said's Avatar
pretty sure they use a type-argh tb for the b series units. they are 70mm at the opening and taper down a little bit, to 68mm i think.
Old Jan 24, 2003 | 04:47 PM
bubbajim's Avatar
Default Re: question on spoon tb... (hanson said)
ive got one, they taper down to 62.
Old Jan 24, 2003 | 04:48 PM
euclid's Avatar
the spoon tb is 70mm then it tapers down tothe stock type-r bore 64mm. it is a stock itr tb.
Old Jan 24, 2003 | 05:15 PM
bubbajim's Avatar
Default Re: question on spoon tb... (euclid)
its 62, weve measured a ton of times, 62.
Old Jan 24, 2003 | 07:26 PM
Old Jan 24, 2003 | 11:33 PM
Kengs's Avatar
Bubbajim is right; the Spoon TB tapers from 70mm>62mm.
Old Jan 25, 2003 | 08:47 AM
JdmVetteEater
Guest
Posts: n/a
Default Re: question on spoon tb... (kengs)
type s is bigger that is how they do it...
Old Jan 25, 2003 | 11:41 PM
euclid's Avatar
Default Re: question on spoon tb... (JdmVetteEater)
62mm i stand corrected
rolow
Sep 4, 2002 06:19 AM
OohOoh
Mar 12, 2002 07:51 AM
ic108
Nov 22, 2001 06:55 AM
ITR111
Aug 24, 2001 07:03 AM
