Swap Question - DX Exhaust on B16A2?
Old Jan 19, 2003 | 09:21 AM
BenB's Avatar
Default Swap Question - DX Exhaust on B16A2?
I purchased a complete B16A2 swap for 1800 yesterday, but the only ehxuast I have is my stock DX exhaust. The piping for the Si header that came with the swap is 2" OD and the piping for my DX Exhaust is 1-3/4" OD.
Will it be ok to run this exhaust on this motor?
Will it be too constrictive, and in effect, harm the motor?
Thanks.
Old Jan 19, 2003 | 09:31 AM
sean's Avatar
Default Re: Swap Question - DX Exhaust on B16A2? (BenB)
i had a b16a2 swap in a 96 cx and i used the stock piping for the longest time. nothing was wrong with my motor, ran fine.
[Modified by sean, 1:31 PM 1/19/2003]
Old Jan 19, 2003 | 09:41 AM
BenB's Avatar
Default Re: Swap Question - DX Exhaust on B16A2? (sean)
What did you do as far as the cat situation? The DX has the cat and 2 02 sensors built into the header where as the Si has an 02sensor in the header, then the cat with another 02sensor. Did you just take the exhaust to a muffler shop and get them to put the cat in between the Si Header and the CX Piping?
Thanks for the reply.
Old Jan 19, 2003 | 11:14 AM
Cody's Avatar
Im also curious about this. Anybody else have any input?
TTT
[Modified by Cody, 8:14 PM 1/19/2003]
Old Jan 19, 2003 | 11:17 AM
b16 matt's Avatar
Default Re: Swap Question - DX Exhaust on B16A2? (Cody)
You can take one o2 sensor out plug the hole and wire one into both computer inputs I did it without codes thrown. I also run a hondata.
Old Jan 19, 2003 | 11:21 AM
stockegsix's Avatar
i went to the same situation when i first did my b16a swap, No its not gonna harm the motor, but the stock DX is exhuast is bottle necking the air flow, go to a muffler shop and get custom piping, preferably 2.25". if you wanna retain stock look and sound, add a resonator and GSR, Type R, or 00si muffler.
Old Jan 19, 2003 | 11:24 AM
BenB's Avatar
Default Re: Swap Question - DX Exhaust on B16A2? (b16matt)
Yes, but don't the two 02 sensors read two different things? I was told one is for fuel/air mixture and one is for heat.
Old Jan 19, 2003 | 11:26 AM
BenB's Avatar
Default Re: Swap Question - DX Exhaust on B16A2? (zzZZzzleeperCX)
I would get some piping, I'm just REALLY strapped for cash at the moment. I already know which aftermarket exhaust I want. Just have to save up some money.
GSX TO CX
Jan 15, 2005 12:22 PM
ej1 pilot
Aug 23, 2004 04:52 AM
Krnbk2
Nov 15, 2003 08:55 AM
lsvtec101
Jun 19, 2002 04:17 AM
hondachick81
Sep 7, 2001 10:25 AM
