SRS Computer removal ?'s - Searched already
Ok well all I found was that it can be done. Here is my question. If I remove my SRS computer and anll connectores will I get a CEL light? Or more importantly will it read that I removed it on my OBD2 adapter?
The only reason I ask is because my airbags are blown and i am getting a new steering wheel. so would like to know if I will pull a OBD2 code if I pull my SRS computer.
TIA.
TIA.
No CEL.
You might have the SRS light come on, but you fix it by unplugging the yellow connector at the back of your guage cluster.
I did both on my 93 CX, and have had no problems at all.
srs computer is completely separate from the 'normal' ECU.
if you put on a wheel with an air bag to pass.... here's how to reset the light
1. turn ignition switch off, remove ECU service connector
2. connect (jump) the MES connector (this is 2 pin yellow connector wrapped in yellow plugged in the front of the underdash fuse box)
3. turn ignition switch on
4. SRS light will come on for 6 secs then go out, remove the jumper within 4 secs after the light goes out.
5. the SRS light will come on again, reconnect the jumper within 4 secs after the light has come on.
6. the SRS light will go off, remove the jumper with in 4 secs after the light has gone off.
7. the SRS light will blink to times indicating the memory is reset.
95DX_D15B
Jun 2, 2006 10:49 AM
solslow
Mar 11, 2005 12:36 AM
