B16 OEM stroking ??????????????
Old Jan 19, 2003 | 08:35 AM
bstock1990's Avatar
Default B16 OEM stroking ??????????????
ive heard of many different theories tha b16 can be stroked with oem parts to 1.8 and even 2.0 if so would anyone recommend some setups!!!!!!
Old Jan 21, 2003 | 02:58 PM
bigblockEG's Avatar
Default Re: B16 OEM stroking ?????????????? (bstock1990)
About time you showed up in Honda -tech... I am sure you will find your answer here... The search function will help...
Old Jan 21, 2003 | 06:00 PM
HXMan's Avatar
You can stroke a b16 with ALL oem parts if you use a b17 crank and rods.
You could put in a b18c or b18b crank in a b16...but you will need custom short rods.
Your R/S ratio will be garbage also with the b18 cranks.
m2theizzy
Apr 27, 2009 08:03 AM
mike_paz17
Nov 29, 2007 04:59 PM
JDMspirit
Oct 17, 2006 07:18 AM
ragerized
Jun 13, 2004 11:09 PM
