Nasty nosie from timing belt area. any ideas?
Old Jan 18, 2003 | 09:27 PM
turboex's Avatar
Default Nasty nosie from timing belt area. any ideas?
On its a b20/gsr head blah blah. the gears are jg light speed and they have scrape marks on the back in a circle as if they have been rubbing some thing, but i cant see what. I started the car for the first time. (new motor just built and sleeved blah blah). But after a few secs it started to squiel (spelling) I fogured it was a bearing but the oil pressure is great and its runs fine. Its some as if it come from the timming blet (exposed) area. its real loud. any ideas guys? thanks again
They only thing i can think of is the tensioner. Ahhhhhhh i dont wanna pull this **** apart again
[Modified by turboex, 6:28 AM 1/19/2003]
Old Jan 18, 2003 | 09:35 PM
espanol's Avatar
Default Re: Nasty nosie from timing belt area. any ideas? (turboex)
Hmmm..That's crazy..What timing belt did you use??..I had a b20/vtec..It was apiece of crap..
Flamenco-T's Avatar
check your tensioner, if it goes, it's a disaster...
it may also comes from water pump sprocket...
are you sure it's not any of the accesories belts ?
Old Jan 18, 2003 | 09:38 PM
espanol's Avatar
Default Re: Nasty nosie from timing belt area. any ideas? (Flamenco-T)
Altenator belt??i know it can't be a/c...race cars don't have a/c...well, at least mine doesn't...
Old Jan 18, 2003 | 11:24 PM
LS-hatch's Avatar
Default Re: Nasty nosie from timing belt area. any ideas? (espanol)
Some do, dont know why. Im actually taking mine off tomorrow. As for the squeal, do check the tensione right away, if its not that double check the scraped gears. You can try holding a long screwdriver from your ear to parts on the engine and see where the noise is the loudest and go from there.
Old Jan 19, 2003 | 04:08 AM
turboex's Avatar
Default Re: Nasty nosie from timing belt area. any ideas? (LS-hatch)
thanks for the advise guys. the alt bel is on super tight, maybe to tight. Yeah that the only acess. belt we have. Ill check the tensioner today to. thanks again. What would a bearing squiel sound like? IM sure a bear would not soound like its in the head, by just for an idea.
Old Jan 19, 2003 | 07:28 AM
nsxmatt's Avatar
Depending on the age of the water pump it could go bad and cause it to make some noise. Since you just rebuilt it I assume you put on a new pump though.
Old Jan 19, 2003 | 07:37 AM
Farnsrocket's Avatar
Default Re: Nasty nosie from timing belt area. any ideas? (nsxmatt)
Did you mess up the back of the timing belt cover that is directly behind the gears? I cut the part that goes over the cam itself so I would not have to remove my gears from the cams when I took out my cams. Well, I did a shitty cutting job and F'ed up the cover and it stuck out and scraped my gears when it was all back together and running.
[Modified by Farnsrocket, 8:37 AM 1/19/2003]
Old Jan 19, 2003 | 07:38 AM
turboex's Avatar
yeah pump is brand new. Has anyone had probs with jg gears?
Old Jan 19, 2003 | 07:53 AM
turboex's Avatar
Default Re: Nasty nosie from timing belt area. any ideas? (Farnsrocket)
there is no timing cover on the motor. just the lower part
Old Jan 19, 2003 | 12:23 PM
speedworks's Avatar
what about the cover behind the timing gears. i've seen these rub aftermarket gears and make all sorts of strange noises. i have had to cut several covers to keep them from rubbing.
Old Jan 19, 2003 | 12:25 PM
turboex's Avatar
Default Re: Nasty nosie from timing belt area. any ideas? (speedworks)
I took that cover off too. the sound seems to have went away for now. hum...
Old Jan 19, 2003 | 02:40 PM
V-SPEC 1's Avatar
It is the back plastic cover behind the gears that's what you're hearing I believe. I've seen that too many times.
Old Jan 19, 2003 | 02:54 PM
turboex's Avatar
Default Re: Nasty nosie from timing belt area. any ideas? (boostedb20vtec)
There is no black plastic behind the gears, we took that off.
Scorchin Civic
Mar 1, 2006 05:25 PM
1SickHb
Oct 4, 2005 09:00 AM
hondeducation
Feb 5, 2004 11:56 AM
dElSleepiE
Jun 1, 2003 08:56 PM
THE GAME IS THICK
Feb 5, 2003 10:56 AM
