will a 98 ex cluster plug n play into a 96 dx? If so......
Old Jan 18, 2003 | 07:41 PM
Hatebreed215's Avatar
Default will a 98 ex cluster plug n play into a 96 dx? If so......
If so what is the green 4 pin port for on the ex cluster b/c the dx cluster doesnt have it. What is that port for? Theres no ohter connection for it on the dash harness.
Old Jan 18, 2003 | 07:44 PM
-Gambit-'s Avatar
Default Re: will a 98 ex cluster plug n play into a 96 dx? If so...... (Hatebreed215)
its a direct plug and play mod. everything from your dx harness will plug into the ex cluster with no problems, and everything will work fine from the little warning lights to the tach.
Ya@inlinePRO's Avatar
i just plugged up the harness in mine and didn't ask any questions. and it worked!
Old Jan 18, 2003 | 10:14 PM
OE Tuner's Avatar
Default Re: will a 98 ex cluster plug n play into a 96 dx? If so...... (kwik2nec)
I think the port you are talking about is for the Cruise Control light. Don't worry about it. YOu don't have cruise. Just plug in everything else and enjoy.
stopspazinout
11
Jun 8, 2011 10:29 AM
eG6haTchY
Aug 12, 2008 04:32 PM
903
May 31, 2005 08:41 AM
89 EF Si
Mar 14, 2005 08:53 AM
whitemike1644
25
Apr 1, 2003 05:20 PM
