PR4 Ecu
Old Jan 18, 2003 | 07:17 PM
Blue_Si03's Avatar
Default PR4 Ecu
I'm trying to use the PR4 OBDO ecu for my SOHC VTEC engine but my car idles at 1500rpm and throwing a Code 12(EGR). But when I put back my PM6, everything runs fine. How can I fix the code so I can run the PR4?
Old Jan 18, 2003 | 10:29 PM
Blue_Si03's Avatar
Default Re: PR4 Ecu (CRXracer89)
So can anyone help?
Old Jan 18, 2003 | 11:54 PM
Jaker's Avatar
The PM6/88-91 Si don't have an EGR. Your PR4 ECU is looking for the EGR valve, and the valve/wiring is not there.
Old Jan 19, 2003 | 07:10 AM
Blue_Si03's Avatar
Default Re: PR4 Ecu (Jaker)
So is there anyway I can bypass this?
Old Jan 19, 2003 | 07:33 AM
charjacq's Avatar
New User
None of those are vtec anyway. Why do you want to use a non-vtec ECU with a vtec engine? You'll be missing 2 maps in your ROM which will make your car run lean when vtec is in.
If you still want to use your PM6, I have a chip with the right program to run your engine. No need for the PR4. PM me if you're interested.
Old Jan 19, 2003 | 06:24 PM
joshwhe's Avatar
i just had in mine, i had code 12 also , its egr some civics dont have one i guess, so thats that one, and for the high idle thing you have more air and gas going into your motor due to it being for a b18 all in all, you can reset your idle. for me it really wasnt any better, infact my car was faster with the pm6.
VtecFreePrelude
Engine Management and Tuning
Jun 27, 2010 11:26 PM
zenon8890
Feb 10, 2007 05:21 AM
gots_a_sol
Aug 4, 2004 05:32 PM
Blue_Si03
Dec 15, 2002 02:08 PM
EGh22aEG
Mar 18, 2002 04:18 PM
