Need the truth!!!
I have heard all kinds of ****, all kinds of #'s so I'm going to ask the R guys if you guys don't know nobody will.
Bottom end Question Set up: 00 GSR
JDM CTR Pistons ITR Rods What the hell will the compression be??? Is it Ok w/94 octan. Or should I go brand name like JE or some other possible better set up. Will there be any clearnace issues and should I get it resleeved. Head will be all skunked out w/stage2's.
Daily driver. Looking for high compression that will be reliable and safe.
According to the calculator (http://www.bojangs.com/calculator/), that setup should net around a 12.3:1 comp. ratio. This shouldn't be a problem on 94 octane, assuming decent tuning.
OE honda parts will be better than aftermarket parts nearly 100% of the time in terms of quality and tolerances.
The B18C1 and C5 blocks share the same bore, the pistons will fit.
Cheap, fast, reliable. Pick two.
mightymaxgst
17
Jul 19, 2006 10:27 PM
^AnDre^
Apr 6, 2005 09:21 AM
HKJ
12
Oct 30, 2003 03:38 AM
flashgsr
Jan 19, 2003 06:41 AM
