Need the truth!!!
Old Jan 18, 2003 | 07:14 PM
flashgsr's Avatar
Default Need the truth!!!
I have heard all kinds of ****, all kinds of #'s so I'm going to ask the R guys if you guys don't know nobody will.
Bottom end Question Set up: 00 GSR
JDM CTR Pistons ITR Rods What the hell will the compression be??? Is it Ok w/94 octan. Or should I go brand name like JE or some other possible better set up. Will there be any clearnace issues and should I get it resleeved. Head will be all skunked out w/stage2's.
Daily driver. Looking for high compression that will be reliable and safe.
Old Jan 18, 2003 | 07:21 PM
TypeR 01 886's Avatar
Default Re: Need the truth!!! (flashgsr)
I am not sure what the compresssion would be, but u should be ok with the 94 octane... go with the highest available to you though
Old Jan 18, 2003 | 08:36 PM
Padawan's Avatar
Darth ModerVader
According to the calculator (http://www.bojangs.com/calculator/), that setup should net around a 12.3:1 comp. ratio. This shouldn't be a problem on 94 octane, assuming decent tuning.
Old Jan 18, 2003 | 08:43 PM
flashgsr's Avatar
Default Re: Need the truth!!! (Padawan)
OK C-speed calculator said 11;56669:1
Old Jan 18, 2003 | 08:51 PM
flashgsr's Avatar
**** I got I was using pr3 when the CTR JDM piston is pct thats dude I have seen the fucken light.
Old Jan 18, 2003 | 09:02 PM
.RJ's Avatar
.RJ
OE honda parts will be better than aftermarket parts nearly 100% of the time in terms of quality and tolerances.
The B18C1 and C5 blocks share the same bore, the pistons will fit.
Cheap, fast, reliable. Pick two.
FastFoot
May 19, 2014 08:42 AM
mightymaxgst
17
Jul 19, 2006 10:27 PM
^AnDre^
Apr 6, 2005 09:21 AM
HKJ
12
Oct 30, 2003 03:38 AM
flashgsr
Jan 19, 2003 06:41 AM
