Clutch Engagement???
Old Jan 18, 2003 | 06:59 PM
97hb's Avatar
Default Clutch Engagement???
I just finish putting my hdss into a b18b. On the stock clutch, it would engage at the middle of the pedal stroke. Now it engages right when I let off the clutch pedal, about a centimeter off the ground. Granted my stock clutch was worn all the way to the rivits , but is this why the stock clutch engaged late and the hdss engages right as I let off the pedal??? I have only drove it 3 miles with the new clutch because I dont want to F*ck it up . Do I have to adjust the clutch pedal or something??? I need help on this one guys.
Old Jan 18, 2003 | 07:02 PM
97hb's Avatar
Default Re: Clutch Engagement??? (97hb)
I also bleed the slave cylinder correctly, no air bubbles just a steady stream of brake fluid .
Old Jan 18, 2003 | 07:04 PM
Lord Helmet's Avatar
that's normal. my act clutch did the same thing and my friend's gsr is the same way. it's what you have to deal with when you have a performance clutch.
Old Jan 18, 2003 | 07:10 PM
tominos's Avatar
Default Re: Clutch Engagement??? (sleeperciv)
yea mine was the same way. after you break it in, it'll engage a little later.
Old Jan 18, 2003 | 07:12 PM
Phaze2 Mike's Avatar
Default Re: Clutch Engagement??? (tominos)
Welcome to the world of aftermarket clutchs. I love the low engagement, feels like your tearing asphault clean off the road when u bang gears.
Old Jan 18, 2003 | 07:15 PM
97hb's Avatar
Thanks for the replys guys. I kinda figured that it would probably get better over time but just wanted to be sure . Think I'll go rack more miles on it to get to the magical 300 mile break in. At least thats what ACT recommends.
Old Jan 18, 2003 | 11:26 PM
Id say at least 300, i usually do 500 to be safe.
Old Jan 18, 2003 | 11:49 PM
nwdave's Avatar
Default Re: Clutch Engagement??? (Nextekhatch)
I wish I had engagement like that
delsolguy, who would l0ve a new clutch but Hondata comes first
Kyle244R948
Nov 26, 2008 01:25 AM
Sonnboy18
Jul 31, 2002 08:25 AM
Steve
Jul 23, 2001 01:42 PM
