... 86 crx engine swap
Old Jan 18, 2003 | 04:43 PM
1.8T_EG's Avatar
Default ... 86 crx engine swap
... i may be picking up an 86 crx si and was wondering what engines are a direct swap... i know d-series engines swap directly into 88-91 crx's... but what about 84-87?... i wanna swap a sohc vtec d16z6 in... lemme know if this is a direct swap or not... thanks...
Old Jan 18, 2003 | 05:07 PM
SEA Hag's Avatar
Default Re: ... 86 crx engine swap (1.8T_EG)
No it isnt a bolt in swap, but you use a DOHC 1.6 from 1st gen INTEGRA then its bolt in. Search more.
Old Jan 18, 2003 | 07:39 PM
xci_ed6's Avatar
Default Re: ... 86 crx engine swap (SEA Hag)
HASport makes a kit for the B-series. Most D-series engines do not bolt into the 1G, but can be made to fit. Another problem is wiring, it is very different. HASport also makes a wiring kit for the B-series swap.
Another option would be to swap the head of a D16A1 onto it. It is a DOHC head, but it is supposed to work and lower compression (great for turbo).
resources:
redpepperracing.com
resource.crx.org
-Dustin
Old Jan 18, 2003 | 08:52 PM
wronghand's Avatar
Here is some good reading on the D16A1 swap.
http://hybrid2.honda-perf.org/tech/westech.html
Old Jan 18, 2003 | 08:56 PM
HatchBox's Avatar
Skoobie no more...
Default Re: ... 86 crx engine swap (wronghand)
good luck...
hey i have some 86 si seats for sale...
9,000rpm-b16
Classic Hondas
Sep 24, 2014 05:30 PM
xryanx6690
28
Jan 29, 2007 11:05 AM
ecks_fourttwo
Sep 20, 2004 12:30 AM
1.8T_EG
Mar 30, 2003 08:13 PM
