turn signals won't work
Old Jan 18, 2003 | 03:29 PM
ErikDaGenErik's Avatar
Default turn signals won't work
i checked the fuse and even replaced it. still doesn't work. anyone have any advice? also, the fuse box IS located under the hood...right? not under the dash?
Old Jan 18, 2003 | 03:35 PM
poison's Avatar
Default Re: turn signals won't work (ErikDaGenErik)
make sure the hazard/turn signal relay is plugged in and functioning. As well as the hazard button plugged in.
Turn signals will not function if the hazard button is unplugged or the relay is not functioning.
Old Jan 18, 2003 | 05:17 PM
1qWiKhAtCh's Avatar
replace fuses if needed, and check the flasher right next to the fuse box, also a possibility...
Old Jan 19, 2003 | 06:28 PM
Benj's Avatar
Default Re: turn signals won't work (1qWiKhAtCh)
My rear left turn signal isn't working...any ideas why? All seem to be working except that rear left one...
Old Jan 19, 2003 | 07:37 PM
clm's Avatar
clm
Default Re: turn signals won't work (Benj)
You may also want to check the wiring. It could have a bad ground or be corroding or something else.
Old Jan 19, 2003 | 08:50 PM
Street Ghost's Avatar
did u try replacing the bulb?
Old Jan 19, 2003 | 10:20 PM
blueeg's Avatar
could be switch. check that.
Old Jan 19, 2003 | 11:51 PM
Foozball26's Avatar
Default Re: turn signals won't work (blueeg)
lol who replaces bulbs that CAN'T be the problem.
But it probably is the buld OR the bulb jarred lose from the socket, I had my front right signal come loose a couple of times and just pushed it in farther to get a better connection.
Old Jan 20, 2003 | 12:45 AM
Default Re: turn signals won't work (foozball-26)
turns out the plug behind the hazard switch wasn't pushed in all the way. everything works now
Old Jan 20, 2003 | 01:37 AM
EK MONEY's Avatar
bulb..
EM2_PLo
Honda Civic (2001 - 2005)
Jul 19, 2010 12:54 PM
Masho
Jul 17, 2010 02:24 PM
ls19integra95
Mar 14, 2008 08:05 AM
blackdude
Mar 20, 2005 07:33 PM
Ming Tsai
Sep 30, 2003 06:43 AM
