tach trouble
Old Jan 18, 2003 | 02:31 PM
90da's Avatar
Default tach trouble
Ok I have a weird problem, I've never seen this happen before. I have a stock tach and an aftermarket tach and when I get up to about 6500-7000 both needles either flap back and fourth or just go up to 8000 on the stock and 10000 on the aftermarket. BTW it's on a d16a6. Any help would be appreciated
Old Jan 18, 2003 | 02:33 PM
USDM 4G VTEC's Avatar
Default Re: tach trouble (90ef)
where are u getting the signal for ur afftermarket tach?? did u tap it to the stock tach??? if not then take the signal off the neg side of the coil inside dizzy
Old Jan 18, 2003 | 02:39 PM
90da's Avatar
Default Re: tach trouble (JDM EF9)
I got the signal from the blue/white wire underneath the dash by the fuse panel. I just want to know why it would start doing it all of a sudden. It worked great before, just all of a sudden....So why would the stock one do it as well???
Old Jan 18, 2003 | 02:51 PM
maybe bc u tapped that cable...
either that or the conection where u tapped the cables its kinda loose and when it gets a strong signal it jumps... rechek all conections.... if it was working before....
Old Jan 20, 2003 | 06:15 PM
90da's Avatar
Well I fixed it, umm well I pulled off the cap, looked at it for 2 seconds(had to go back to work soon) put the cap back on, and when I left work the tachs worked fine. Gotta love cars sometimes
Old Jan 20, 2003 | 06:26 PM
told u so
[Modified by JDM EF9, 10:26 PM 1/20/2003]
[Modified by JDM EF9, 10:27 PM 1/20/2003]
Old Jan 20, 2003 | 06:34 PM
90da's Avatar
[QUOTE]Well I fixed it, umm well I pulled off the cap, looked at it for 2 seconds(had to go back to work soon) put the cap back on, and when I left work the tachs worked fine. Gotta love cars sometimes
told u so
I tapped into the wire under the dash, not the dizzy....So I guess a connection must have been loose and I just bumped it by accident because I didn't have time to actually do anything. Thanks for the help though.
[Modified by 90ef, 3:35 AM 1/21/2003]
Old Jan 20, 2003 | 08:11 PM
JDMBOLONI's Avatar
who is this in St. Catharines???
Old Jan 21, 2003 | 03:44 PM
90da's Avatar
Default Re: tach trouble (JDMBOLONI)
No no...the question is who are you
JaY Horrocks.
Cloneufc
Sep 29, 2012 06:36 AM
drSquish
Dec 28, 2006 01:20 PM
hughesl
May 15, 2005 03:39 AM
Beezle
Nov 2, 2004 10:33 AM
