Found source of oil leak.. now what??
Old Jan 18, 2003 | 01:28 PM
MeanGreenEG9's Avatar
Default Found source of oil leak.. now what??
Found out my block was leaking oil bout two weeks ago and posted here.. thanks for all the help btw. I was able to use a small mirror to find out exactly where the leak was comming from. The culprit... just as expected.. the oil pressure sensor... so i took it out.. coated the threads with high temp RTV and bolted it in by hand. Now I dont know if its becuase i didn't use a ratchet to bolt it down or if its becuase that sensor is messed up but it STILL leaks oil from that hole. And the leak is not a very slow leak either.. the flow is pretty fast.. so what do you think it could be? do i have to bolt it down with a ratchet?? i dont see how the hell you could fit a ratchet in that tite *** spot unless i took the intake manifold off.. I guess i'm left with that? also why does the sensor leak? are the threads bad? i checked that already and I didn't see any broken threads. Could it be the threads INSIDE the block thats stripped? I was actually thinking about just taking a short bolt and bolting it down with that since the sensor really isn't needed... any suggestions?
Old Jan 18, 2003 | 02:15 PM
Chiovnidca's Avatar
Default Re: Found source of oil leak.. now what?? (SlowAssB16a)
LOL, replace the sending unit.
Old Jan 18, 2003 | 05:46 PM
Default Re: Found source of oil leak.. now what?? (Chiovnidca)
well that would be the most logical thing to do but i looked at the one i got and nothing is wrong with it.. the only reason it would leak is if the threads are messed up right?
Old Jan 18, 2003 | 05:59 PM
Chiovnidca's Avatar
Nope, the body of them tend to leak.
Old Jan 18, 2003 | 06:54 PM
irev210's Avatar
i happen to have a sending unit in perfect working order
PM me for price
Old Jan 18, 2003 | 09:16 PM
Shawn C's Avatar
In The Garage
Default Re: Found source of oil leak.. now what?? (irev210)
i might add that i would also use teflon tape instead of rtv on the threads, making sure not to cover the hole in the sensor. and maybe tighten with a wrench (tighten to specs)
[Modified by 22lbGS-R, 12:23 AM 1/19/2003]
Old Jan 18, 2003 | 09:40 PM
tominos's Avatar
Default Re: Found source of oil leak.. now what?? (22lbGS-R)
yea can't u just use an open end wrench?
Old Jan 19, 2003 | 04:37 AM
b19coupe's Avatar
If the oil sending unit is not properly torqued, it will leak. Teflon tape the threads and torque it. Don't put a bolt in the hole, the threads in the block are tapered and you will have more of a problem than you started with.
Old Jan 19, 2003 | 01:40 PM
Default Re: Found source of oil leak.. now what?? (b19coupe)
Well I wrapped the threads in teflon tape and bolted it down with a rachet.. Drove the hell out of the car for a good 30 mins and not ONE dab of oil seeped from the sensor. Thanks for all the members that helped me out in all this.. I couldn't have done it alone
Old Jan 20, 2003 | 11:04 AM
fathergoose's Avatar
The oil pressure leaks from its seal, not from the threads, your have to replace it and torque it with a ratchet and a deep socket I think it's 22mm.
mr.mengo
Mar 1, 2013 04:05 PM
boostmee
Aug 18, 2008 02:05 PM
93CharcoalHatch
Welding / Fabrication
13
Jan 7, 2006 07:59 PM
eg crunkmonster
Feb 3, 2004 08:47 PM
VTgringo
Jun 30, 2003 07:36 PM
