trans fluid check?!?!?
Old Jan 18, 2003 | 11:22 AM
4ghatch's Avatar
Default trans fluid check?!?!?
where is the dip stick for the trans fluid in my 91 dx hatch?
[Modified by 4ghatch, 2:35 PM 1/18/2003]
Old Jan 18, 2003 | 11:28 AM
Ef Whore's Avatar
Default Re: trans fluid check?!?!? (4ghatch)
First of all youre name is 4ghatch, and you say you have a DA? Specify whether or not you have a auto or manual trans---if auto, it is a yellow handled dipstick of the top-front of the trans--u cant miss it. Manual--there is none.HTH
Old Jan 18, 2003 | 11:34 AM
4ghatch's Avatar
Default Re: trans fluid check?!?!? (Ef *****)
it is a manual trans. If i dont have one how can i check and or fill it? also what is a DA????
Old Jan 18, 2003 | 11:39 AM
Ef Whore's Avatar
U cant "check" it, only drain/fill/top it off ---a DA is a 90-93 Integra.
Old Jan 18, 2003 | 02:42 PM
90da's Avatar
There is a bolt you remove to fill it up on the side of the tranny....take that out and stick your finger in.
Old Jan 18, 2003 | 02:45 PM
ULTRA911's Avatar
Default Re: trans fluid check?!?!? (90ef)
and if you could touch the fluid, the level is ok. pour more if necessary then keep on fingering it!
Old Jan 18, 2003 | 10:50 PM
guttedEF's Avatar
You have to be under the car to check the tranny fluid on a manual. There are two bolts on the passenger side of the tranny.
The top one is the check hole and should take a 17mm wrench to remove. Like he said, just remove it and stick your finger in. If you can feel it, it's good. If not, fill it up and check again. You can use either 10w-30 motor oil, or preferably, Honda MTF.
Also, just so you know, the bottom one is the drain hole. It should take a 3/8 ratchet to remove. Ony remove this if you're planning on changing all the tranny fluid though.
[Modified by guttedEF, 11:51 PM 1/18/2003]
Old May 13, 2003 | 08:21 AM
Lo-Buck EF's Avatar
(holy old thread)
i did a search but couldnt find anything...... How mmany quarts does an ef manual trans take roughly? i changed it last spring, but i dont remember...
-spenc
Old May 13, 2003 | 08:26 AM
SloCivicHMM's Avatar
Default Re: trans fluid check?!?!? (SOLOef)
I believe barely 2qts........at least thats what it was in my hydro d series tranny.....split some but after fingering the hole it was determined filled!!
Old May 13, 2003 | 08:27 AM
pokemon's Avatar
1.9 us qts
Old May 13, 2003 | 08:37 AM
Lo-Buck EF's Avatar
Default Re: trans fluid check?!?!? (SlowCivicHmm)
excelant, thatks guys.
-spenc
Coffey CupHonda
Jun 11, 2017 08:44 AM
jmh4bb6
Apr 6, 2013 06:01 PM
GoLowDrew
Transmission & Drivetrain
Feb 15, 2010 10:32 AM
stevescivic
Feb 28, 2007 03:44 PM
LABMONK-E
Acura TL, RL & ZDX
Aug 8, 2004 09:18 AM
