any nitrous people please click here.. need some help on an install...
i'm in the middle of installing my NOS kit. i have a 91 crx, with a zc engine. basically i'm having trouble mounting the WOT switch. i cant seem to find a good spot to mount it. i have tried a few spots and some times it makes the throttle catch, which is quite dangerous in my opinion. my friend said that maybe i should mount it underneath the pedal.
if anybody has some pictures that'd be amazing. or even a diagram or detailed description would do.
thanks !
if anybody has some pictures that'd be amazing. or even a diagram or detailed description would do.thanks !
Guest
Posts: n/a
the one on my ZC had teh bracket bent. then slipped in between the top bolt facing the front of the car on the throttle body.
just make sure you mount it where when the throttle linkage is WOT, it clicks the switch.
i'm looking for pics, because i know i have close ups of the area when i was taking pics of vacuum lines...
yeahh if u have pics please post them, if not caan you email them to me... it'll really help when the time comes to do the install.
you dont have to have the wot.
I just made a metal bracket by bending a small piece of metal then drilling a hole on each side. One for the switch, and one to attach it on. I put the switch right under the piece that swings down at wide open throttle on the TB. Hope that helped I will see if I can get a digital camera to show you.
Aeka GSR
Apr 19, 2004 09:54 AM
