nitrous
Old Nov 1, 2001 | 04:45 AM
stangkilla's Avatar
Default nitrous
could anybody help me with how to hook up a wide open throttle switch to my throttle body. and if you know any howto's on how to install nitrous that would be very helpfull
Old Nov 1, 2001 | 05:08 AM
rtype11's Avatar
Default Re: nitrous (stangkilla)
isnt it on/behind your gas pedal that activates the solenoids - found your problem, get away from the motor before you break something.
Old Nov 1, 2001 | 05:30 AM
b18bturbo's Avatar
Default Re: nitrous (rtype11)
actually the nos kits come with a microswitch that mounts to the tb and is activated by the tb lever when it its full rpm. It pretty simple to do on a honda use the second bolt and bend it to fit. where you hit full throttle
Old Nov 1, 2001 | 08:56 AM
PM-Performance's Avatar
Default Re: nitrous (b18bturbo)
yea i got mine on the tb with my nos kit . . . .. i wouldnt suggest that behind the pedal thing.
Old Nov 1, 2001 | 10:06 AM
riot's Avatar
Grab a 10mm bolt out of something in the engine bay that you don't need like a bracket or whatever...I used one bolt out of the black platform by the tach signal. bend the microswitch mount so the hammer activates the switch and then use the bolt to tighten the mount on...
Your going to have to play with it until you get it just right...it's a pain in the ***.
-ryan
Rad Racing
Sep 24, 2005 07:00 AM
95accordh22a
Feb 26, 2005 08:35 AM
Aeka GSR
Apr 19, 2004 09:54 AM
TRE_
Jan 19, 2003 10:15 AM
stangkilla
Nov 1, 2001 07:50 PM
