ITR tps sensor
Old Jan 18, 2003 | 07:48 AM
1QWKGS's Avatar
New User
Default ITR tps sensor
I have a 1998 Integra GS and I'm looking to put a ITR throttle body on. The only problem is that it's missing the tps sensor. I was wondering if my tps sensor is the same and could I swap them?, or do I have to buy a ITR tps from a junk yard?. Would civic tps work also??
Old Jan 18, 2003 | 12:51 PM
misledyouth's Avatar
New User
Default Re: ITR tps sensor (1QWKGS)
if it's usdm you can't put on the tps becuase they are riveted on. but if it's jdm then they are held on by 2 screws and you can switch and adjust them.
jesse
Old Jan 18, 2003 | 06:11 PM
nsxmatt's Avatar
Default Re: ITR tps sensor (misledyouth)
If it's USDM then it is held on with rivets but you can take a dremel and slot the rivet and unscrew it and put it back on with normal hex head screws like the JDM ones. And yes your TPS will swap over no problem
Old Jan 18, 2003 | 07:43 PM
DirtySohcs's Avatar
pretty much any 88-00 Civic/integra/crv TPS are swappable. The only one i can think of that won't work is the d15 from the 88-91 Civic DX/LX/STD motor and it is too big.
Old Jan 18, 2003 | 08:04 PM
irev210's Avatar
Default Re: ITR tps sensor (DirtySohcs)
stupid USDM
why did they have to rivit
Old Jan 19, 2003 | 12:07 AM
Jaker's Avatar
Default Re: ITR tps sensor (irev210)
They are not rivets. They are screws with heads that break off when you get to a certain torque. This is to prevent tampering. However, as someone already mentioned above, all you need to do is slot the blind head of the screw, and take them out with a slot screwdirver. I usually do it carefully with the hacksaw.
Old Jan 19, 2003 | 01:00 AM
BudaKai's Avatar
Default Re: ITR tps sensor (Jaker)
Sorry to chime in,but those two words "hacksaw" and "carefully" don't belong in the same sentence.
Old Jan 19, 2003 | 11:51 AM
Jaker's Avatar
Default Re: ITR tps sensor (tzsir)
Depends on your level of competence!
SiMateoAko
May 28, 2006 01:44 PM
PrettyLakesBoy
Mar 15, 2005 03:21 PM
Gs-RAW
Sep 2, 2003 09:38 PM
civic disobedience
Mar 29, 2003 09:53 AM
3gLudeH22A
Jun 12, 2002 09:09 AM
