Loose seatbelts!
Old Jan 17, 2003 | 10:57 PM
91 civic's Avatar
Default Loose seatbelts!
OK, the seatbelts attached to the door of my 91 hatch are so damn gay. Every time I take the seatbelt off I have to hand feed it back into the damn door or it shuts in the door and breaks off more of the door. Is there a way to fix this, or tighten the springs?
Old Jan 18, 2003 | 12:06 AM
matt j's Avatar
Default Re: Loose seatbelts! (91 civic)
take it to the honda dealership, they warrenty any seat belt problems, my guess is that your retractor went out and isnt returning the belt back. but like i said the dealership has to fix it for FREE
FRESH's Avatar
I ******* hear yah.. i hate that **** esp on the passenger side when foos get out of my ride they shut the door and the seat belt tears the plastic trim and the door moldings and what not...You probley gotta buy a new winder or whatever is inside of the door i dont think you can adjust it..
Old Jan 18, 2003 | 07:19 AM
CRXTSEE's Avatar
Default Re: Loose seatbelts! (FRESH)
I have the same prob.... my door jamb is all dinged up
Old Jan 18, 2003 | 08:13 AM
importfan85's Avatar
Default Re: Loose seatbelts! (CRXTSEE)
Does anyone else know if it is true that they have to fix it for free. That would be awesome, right now my seatbelts suck a fatty.
Old Jan 18, 2003 | 09:04 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Loose seatbelts! (importfan85)
I hate that too when peeps slam the door shut and the seat belt takes out a huge chunk of the door pannel. Both of mine look ilke some one empited a machine gun clip into em.
Old Jan 20, 2003 | 09:41 PM
matt j's Avatar
Default Re: Loose seatbelts! (CRXSiBeater)
http://www.alldata.com/TSB/24/912422AI.html
Old Jan 20, 2003 | 09:48 PM
Louie B.'s Avatar
the door seatbelts are designed to be left hooked up, you're suposed to be able to get in and out without disconecting them. So, to be able to have the belt stretch out enough to do this, they don't have enough spring left when you retract them in. Honda accually designed them this way. Even if they do replace them for you, they'll start doing the same thing again soon after.
Old Jan 20, 2003 | 10:47 PM
RCautoworks's Avatar
Default Re: Loose seatbelts! (hybridturbo89)
Yep, they have been recalled so they must fix it for free.
Old Jan 20, 2003 | 11:37 PM
CLICC916's Avatar
i've had my seatbelts REPLACED for free from honda...take it to them and see what they can do...i told em about the same thing. they just told me that that's the way the seatbelts were designed
Old Jan 21, 2003 | 10:21 PM
Louie B.'s Avatar
Default Re: Loose seatbelts! (CLICC916)
I talked to the service manager at my local honda dealer today and he said there is nothing wrong with my seatbelt so there's nothing to fix. a new seatbelt will do the same thing. you're not suposed to unhook the belt, therefore, it's not supposed to retract all the way into the door. It's just too long for the springs to be able to pull. Now, if the belt didn't retract at all, or it had a tear that wasn't obvious missuse, they would have no problem at all replacing it.
I'm taking my door panels off tomorow to change my door handles, while I'm in there I'm going to play around with the belts a little and see if there's a way to tighten it up.
Old Jan 24, 2003 | 06:34 AM
Louie B.'s Avatar
That's pretty much what they told me... if i can prove they're loose WHILE WEARINNG THEM, they'll replace them.
singlecamsaint
16
Mar 5, 2012 04:44 AM
KRock459
Paint and Body
Jan 14, 2009 06:05 PM
Cln94EG1
Sep 27, 2008 01:21 PM
Silent_Destruct
Jan 15, 2007 10:03 PM
type Gendy
Jan 4, 2005 12:22 PM
