Another Problem (fuel injector problem) about to do a Obd2 B18b swap in my 98 EK
Old Jan 17, 2003 | 06:44 PM
civicrtype's Avatar
Default Another Problem (fuel injector problem) about to do a Obd2 B18b swap in my 98 EK
K pretty much got all the parts except for the axles and mounts but one problem. I bought a 99LS motor but it was previously used on an 92hb. So the guy i bought it from changed the intake manifold and the engine harness. Well now I got the right harness (OBD2), and i installed a 99LS intake manifold w/all sensors. But I used the Fuel injectors that were on the 95 manifold. I noticed that the plugs for the injectors were different. Well here goes, My 98 EK which is OBD2 has the right plugs. I was wondering if I could just use the injectors of my DX motor? I was wondering about the flow rate but I checked http://home.earthlink.net/~pritos/ci...tml#enginjflow and it says that all D series and B series Fuel Injectors all have the same flow rate of 240cc/min.
SO what do ya think? Can I use mines? Its should just bolt in right? Well if u guys can help I would appreciate it. Thanks.
Old Jan 17, 2003 | 07:00 PM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Default Re: Another Problem (fuel injector problem) about to do a Obd2 B18b swap in my 98 EK (civicrtype)
I believe that you can. I was going to use the injectors off of my SOHC and use them on his LS motor.
Old Jan 17, 2003 | 08:12 PM
civicrtype's Avatar
Default Re: Another Problem (98coupe)
Thanks i figured that.
Old Jan 17, 2003 | 08:19 PM
slammed_93_hatch's Avatar
Default Re: Another Problem (civicrtype)
that kinda lame that he did that he could have used the same everything it all will plug in
Old Jan 17, 2003 | 08:54 PM
civicrtype's Avatar
Default Re: Another Problem (slammed_93_hatch)
Yup i thought so too, but I noticed a few different plugs on the obd2 harness compared to the obd1, i guess thats why he did it, dumb though.
jesse.pulido
Jun 29, 2013 04:57 AM
sive
May 17, 2012 12:42 PM
>-Mika-<
Aug 17, 2009 11:05 AM
quick4thgen
Aug 30, 2007 04:33 AM
rhd
15
Feb 16, 2005 04:53 AM
