Car won't start, need help.........
Old Jan 17, 2003 | 04:04 PM
Noe Kozz's Avatar
Default Car won't start, need help.........
I just got my car back from the mechanic who was gone for the day. The car started fine, filled her up with gas, everything good. So I'm driving over to the supermarket. Come back, car won't start, thought it was the battery, got jumper cables, car won't start. I'm thinking it's a bad alternator, but I'm not sure. They told me they kept my old alternator and hooked it up to the new motor. My question is,
could it be the alternator?
If it is the alternator, my old one worked, could it have died after they swaped it?
Any help would be gladly appreciated. I would have checked it out myself, but I was in a supermarket parking lot so it's sort of inconvinient. Any input would be appreciated.
Old Jan 17, 2003 | 06:25 PM
tominos's Avatar
Default Re: Car won't start, need help......... (VTEK 4 U)
car should start with a jump even if alternator's bad i would think.
Old Jan 17, 2003 | 06:34 PM
slomofo's Avatar
GDD Member
Probably has something to do with your ignition, check your coil or if it's an accord, it's most likely your ICM.
[Modified by slomofo, 3:40 AM 1/18/2003]
Old Jan 17, 2003 | 07:36 PM
Noe Kozz's Avatar
Default Re: Car won't start, need help......... (slomofo)
you think so? I was also thinking maybe bad grounding. I mean, the car started fine, turned it off to get gas, turned it back on and everything was fine. Whent to the store for a about 5 minutes, car wouldn't start. I know it's an electrical problem.
Old Jan 17, 2003 | 07:41 PM
slomofo's Avatar
GDD Member
Could be a bad ground, I was just giving a possibility. I work at a shop and see accords and integras towed in at least four or five times a day and they all have a starting problem which is bad coil on civics/integras, or bad ICM's on other hondas with external coils(accords).
Old Jan 17, 2003 | 08:21 PM
PnX-R's Avatar
Dang that must suck.. Well, there's really not enough info there..
Does it even try to crank over??
Did you try turning the key and then stepping on the clutch??..
I don't know.. Good Luck though..
Old Jan 17, 2003 | 08:39 PM
Noe Kozz's Avatar
Default Re: Car won't start, need help......... (PnX-R)
I guess I'll have to wait until tomorrow morning to figure it out. I'll take off one of the plugs to see if I get spark. It's not the fuel pump, because I get the hummm from the rear.
Old Jan 17, 2003 | 10:24 PM
icelarry27's Avatar
yeah that sucks, check sparks and battery and ****...
Old Jan 17, 2003 | 10:39 PM
RCautoworks's Avatar
Default Re: Car won't start, need help......... (GRCuadros)
I am having a starting problem myself, the car ran fine when my dad jumped it. But after letting it sit for 1 hour it would not start back up. I replace the alternator and it did not work. Autozone also gave me a new battery but it still did not work. I am pretty sure its the starter. Read my other post about it for more information.
[Modified by 90blackcrx, 1:40 AM 1/18/2003]
Old Jan 18, 2003 | 06:00 AM
Noe Kozz's Avatar
Default Re: Car won't start, need help......... (90blackcrx)
Hit your starter with something to see if it starts up. Today I woke up early, and started messing with the harness and the car turned on. 9/10 times it's electrical. Also check if you have spark. If you don't, it's electrical, if you do, it's something else. Tomorrow or Monday, I'm gonna spend some time and mess with the harness wires again. I might have bad contact or a wrong ground wire. My old headlight harness was cut off (from when I bought the car). So the way the wires were re-arranged, somehow caused some static. I'll keep you guys updated.
Old Jan 18, 2003 | 06:01 AM
Noe Kozz's Avatar
also check your distributor cap and coils.
ScalCG6
Mar 28, 2019 04:56 PM
bigislandc2
Jun 2, 2008 02:48 PM
aznsins88
Dec 30, 2004 09:10 PM
Noe Kozz
Jan 18, 2003 05:57 AM
94HybridEX
Oct 10, 2002 10:06 AM
