Gearing Question!!
Old Jan 17, 2003 | 02:27 PM
HondaGSR's Avatar
Default Gearing Question!!
OK, Suppose you had any and all trannies out there to fit a "B" series. What would you say is the perfect gearing for a tranny, if you were to take a gear from this tranny and one from that tranny so on and so forth. So what tranny with what gears would be the best setup???
[Modified by HondaGSR, 7:01 PM 1/17/2003]
Old Jan 17, 2003 | 03:01 PM
HondaGSR's Avatar
Default Re: Gearing Question!! (HondaGSR)
up
Old Jan 17, 2003 | 03:40 PM
altoid's Avatar
depends on your cars application, autoX, drag, rally, etc...
Old Jan 19, 2003 | 03:55 PM
HondaGSR's Avatar
Default Re: Gearing Question!! (altoid)
OK, how about the occasional SCCA auot-x, occasional drag race, but also a good street setup.
Old Jan 19, 2003 | 05:02 PM
texan's Avatar
For the most part, that's three mutually exclusive things in terms of optimal gearing. Just go with the most evenly spaced out 1-4 possible, with a 1st that'll have you redlining at no higher than 35-40 mph.
Besides, there is very little difference in factory B series gear ratios. The Y21/S21 ratios with a Type R style 4.785 final are the best the factory has to offer.
Old Feb 3, 2003 | 04:12 PM
B16b2b's Avatar
Default Re: Gearing Question!! (texan)
i bet he already found that out, j/k tenis
Old Feb 3, 2003 | 05:16 PM
HondaGSR's Avatar
Default Re: Gearing Question!! (B16b2b)
BLAH BLAH BLAH, Maybe first through thrid, Top End is a Different Story!! But that Tranny Does KICK ***!!!
masonracing
Dec 27, 2011 02:14 PM
josh green
Jan 12, 2006 06:23 PM
NINJASPY
13
Aug 2, 2004 03:26 PM
GG-SquadDB
Mar 17, 2004 07:10 PM
