hmmm b18c1 with type r head
Old Jan 17, 2003 | 11:47 AM
viCeVerSa's Avatar
Default hmmm b18c1 with type r head
well im jsut wondering , ive read about the ls vtec and b20 vtec and stuff and i have read that the bad part , is that the R/S was wither to high or low i forget , and that stands for the rod to stroke ratio , and the problem with the frankenstein motors is because of their R/S the rod pushes the piston more into the walls of the block than straight up, makeing the engine not last as long..... would the gsr with the tpe r head have the same problem? sorry if this doesnt yeild enouggh info ill try to find more
Old Jan 17, 2003 | 12:23 PM
Targa250R's Avatar
be professional
Default Re: hmmm b18c1 with type r head (ErollinC)
No. You can't change the rod/stroke ratio unless you change the rods and/or the crank; simply changing the head won't affect it.
Old Jan 17, 2003 | 07:36 PM
viCeVerSa's Avatar
Default Re: hmmm b18c1 with type r head (Targa250R)
so what i read was false and there is no down side to running frankenstien engines?
Old Jan 17, 2003 | 08:08 PM
Evs-One's Avatar
Solbros Owns Me
there is when you take a bottom end designed for low RPM's and rip it to 9 grand.
Old Jan 17, 2003 | 08:44 PM
Brewer's Avatar
Default Re: hmmm b18c1 with type r head (Emerica)
Haha... damn 9 grand.... that's way on up there
Old Jan 17, 2003 | 08:48 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: hmmm b18c1 with type r head (BrewerHatch)
always use extremes for examples. The point tends to stick a little better.
For instance, I don;t know the figures and schlock, but who cares. CRV engine usually operate up to around 6 grand. The rod/stroke ratio is designed to best compliment this type of driving and help put down the torque. The Type R head and easily give power through 9 grand because of it's design, plus the rod.stroke ratio allowing it to do so relatively safe. Whatever, too tired
Old Jan 17, 2003 | 08:49 PM
IS3Fifty's Avatar
Old Jan 18, 2003 | 08:32 PM
viCeVerSa's Avatar
Default Re: hmmm b18c1 with type r head (purek9hybrid)
ok so an lsvtec, with a b16a head, should say be fine as long as it isnt reved higher than 8000?
Old Jan 18, 2003 | 09:09 PM
2k1_ITR_0736's Avatar
Default Re: hmmm b18c1 with type r head (viCeVerSa)
well i have gsr with ITR head, runs good, and i rip that **** to 9500 all day everyday, actually only when i plug my hondata in. right now im running stock p28 with VAFC witha hurtin 7300 Rev limit, needed to leans that **** out, 370cc injectors hurt my fuel MPG
:-P
im also putting together a frankenstien right now, gsr head on b18a. should be good for some alright power. then put some boost on the biatch.
[Modified by 2k1_ITR_0736, 1:10 AM 1/19/2003]
Old Jan 18, 2003 | 09:20 PM
Shawn C's Avatar
In The Garage
Default Re: hmmm b18c1 with type r head (2k1_ITR_0736)
also keep in mind compression ratio- its gonna drop with a type-r (B18C5/B16B) or an Si (B16A) head on a gs-r (B18C1) block, since the heads are from engines with high-dome pistons. the gs-r has ~flat-top pistons, besides the valve recesses. compression loss = power loss
jrhdominos
29
Jan 30, 2012 03:01 AM
zeusone2
Jun 21, 2011 08:03 PM
Lil Gnome
Oct 20, 2008 08:02 AM
rEnZ94tEgGy
Jan 31, 2008 05:29 AM
out there
25
Apr 29, 2004 02:35 AM
