Diluted coolent causes bad gas mileage?
Old Jan 17, 2003 | 11:33 AM
MeanGreenEG9's Avatar
Default Diluted coolent causes bad gas mileage?
As you all might already know for some reason I've been getting the shittiest gas mileage... I also noticed that lately its been taking a good 20 mins of driving (on the highway) to get my thermostat to hit the normal line right below the bulb.. I might have put too much water in the radiator which diluted the antifreeze.. so could it be that since its been like 20 degrees out here lately that the diluted coolent is why its taking longer to warm the engine up? I heard someone say check your coolent if you are getting bad gas mileage.. i guess the reason that it could hurt it is a warm running engine is more efficient? am i wrong in thinking this?
[Modified by SlowAssB16a, 12:34 PM 1/17/2003]
Old Jan 17, 2003 | 11:44 AM
1bad-eg's Avatar
Default Re: Diluted coolent causes bad gas mileage? (SlowAssB16a)
You might want to check your thermostat to see if it is sticking. I know that here at acura we do a 50/50 mix(50%water 50%coolant) cause that's what Honda recommends.
Old Jan 17, 2003 | 11:49 AM
Perfectionist's Avatar
A cold running motor will waste gas. Replace your thermostat.
Old Jan 17, 2003 | 12:14 PM
Default Re: Diluted coolent causes bad gas mileage? (Perfectionist)
but if its the thermostat sticking that shouldnt' actually make then engine run cold... it would just make it LOOK like its cold right?
Old Jan 17, 2003 | 12:33 PM
RaceTilIDie's Avatar
More water will make the car run cooler. Just pay the $7 and change the coolant.
Old Jan 17, 2003 | 12:41 PM
1bad-eg's Avatar
Default Re: Diluted coolent causes bad gas mileage? (RaceTilIDie)
Yeah, the more water flow the thermostat lets pass through the cooler the engine.
Old Jan 17, 2003 | 02:00 PM
7 dolla??? then how will i eat???
Good idea though..
Old Jan 17, 2003 | 02:03 PM
speedymon's Avatar
Default Re: Diluted coolent causes bad gas mileage? (1bad-eg)
If the water is flowing too fast through the engine it won't have time to soak up the heat like it's supposed to. Is this true. I've <U>heard</U> it somewhere. Anyone?
Old Jan 18, 2003 | 08:54 AM
HuskerHybrid's Avatar
antifreeze lowers the boiling point in water. water boils at 100 deg C. by adding coolant it will drastically lower that temp. the 2 purposes of coolant is to 1) make your engine not freeze and seize up 2) allow your engine to quickly get up to operating temperatures. 50:50 mixture allows the optimum ratio for this. too much coolant and you're car won't heat up quick enough. too much water and your car my heat up too much and/or possibly have trouble starting up.
Old Jan 18, 2003 | 09:45 AM
brianbrannon's Avatar
Default Re: Diluted coolent causes bad gas mileage? (HuskerHybrid)
You have a bad thermostat. The water to coolant ratio isnt that important. Just get a coolant tester and make sure you have enough freezing protection for your climate. Coolant raises the boiling point of water and lowers the freezing point, it is just a modifier for the water. When you change your thermostat it is also a good time to change your radiator cap.
Old Jan 18, 2003 | 12:08 PM
Default Re: Diluted coolent causes bad gas mileage? (brianbrannon)
Smokin' Iron
Dec 23, 2009 05:57 PM
jspek29
12
Mar 23, 2004 04:28 PM
Propulsion
Feb 21, 2004 12:20 PM
CC2
Nov 4, 2002 04:02 PM
SpoonPL
Jul 11, 2002 06:52 PM
