center console trouble
Old Jan 17, 2003 | 10:36 AM
neonxrt's Avatar
Default center console trouble
i have a 92 VX, and when removing the console, There are two brass colored screws towards the middle under a little plastic cover that hold the two pieces (front and back) together and onto the floor which are as tight as a 10 year old virgin......anyone else have trouble with these screws? any suggestions before i drill the bastards out? thanks!
MIKE
Old Jan 17, 2003 | 12:14 PM
neonxrt's Avatar
Default Re: center console trouble (neonxrt)
ttt
Old Jan 17, 2003 | 12:22 PM
TurboBumblBee's Avatar
get a good p2 or p3 (p2 p3 meaing size) phillips skrew driver and get them out.. they should not be taht difficult.. maybe try some wd40 to help out also dont drill them out tho
Old Jan 17, 2003 | 01:07 PM
neonxrt's Avatar
Default Re: center console trouble (Hybrid95CivicEX)
WD-40
Old Jan 18, 2003 | 10:20 AM
euclid's Avatar
turn right to tighten... left to loosen
j/k good luck
Old Jan 18, 2003 | 12:40 PM
neonxrt's Avatar
Default Re: center console trouble (euclid)
oh, i thought since it was JDM that it was right to loosen and left to tighten....ha ha ha
MIKE
Old Jan 18, 2003 | 02:44 PM
tommyboy's Avatar
I had the same problem with my car when I was putting in my new consol W/ arm rest. I ended up stripping the hell out of the screws. Those screws are rusted to the frame so in order to get them out you have to use vice grips with the needle nose. To ensure the problem doesn't occur agian, put some graphite lube in the two holes before you put the new screws in.
Old Jan 18, 2003 | 03:23 PM
black2kcivic's Avatar
Default Re: center console trouble (tommyboy)
Lefty Loosy, Righty Tighty y0!
Old Jan 30, 2003 | 12:28 PM
neonxrt's Avatar
did you just grab the head of teh screw with the vice grips, or what?
MIKE
Old Jan 30, 2003 | 05:16 PM
tommyboy's Avatar
No, I used the vicegrips to turn the stripped screws out.
Old Jan 31, 2003 | 08:27 AM
neonxrt's Avatar
to turn the stripped out screws? what would you suggest then to the scres that will not turn? i think they are pretty rusted, i got one out, and it was so brown it looked like a threaded turd . the other won't budge! I am going to get under the car sometime soon, and see what i can do from under there. Meanwhile, any suggestions are appreciated. thanks!
MIKE
graham_ott
Honda Civic (2001 - 2005)
Jun 29, 2015 10:12 AM
BLU BY U
Acura TL, RL & ZDX
Aug 12, 2008 10:06 AM
GO-FIGHT-KILL
Sep 15, 2006 11:00 AM
KOREAN
Jul 7, 2005 06:44 PM
REDTOPAlchemy
Aug 27, 2004 11:30 AM
