HELP!!!!!!CEL #9 CYP Sensor (Cylinder)???????
Old Jan 17, 2003 | 10:02 AM
TheSaianITR's Avatar
Default HELP!!!!!!CEL #9 CYP Sensor (Cylinder)???????
i have this code on my car and i dont know what it means,help!!!!!!
Old Jan 17, 2003 | 10:09 AM
EE_Chris's Avatar
Default Re: HELP!!!!!!CEL #9 CYP Sensor (Cylinder)??????? (TheSaian)
This sensor is located inside of your distributor along with two others: CYL or cylinder sensor and TDC or top dead center of #1 piston.
These sensors are incorparated (sp?) into the distributor housing, so if you have to replace one, your really replacing all three at once....you just have to transfer over the igniter, coil, dust sheld, and rotor to the new housing.
Break out your Helms and a mutli-meter and follow the troubleshooting procedure.
Old Jan 17, 2003 | 11:17 AM
sgT's Avatar
sgT
generally it means, replace the distributor
Old Jan 17, 2003 | 02:00 PM
Chiovnidca's Avatar
Default Re: HELP!!!!!!CEL #9 CYP Sensor (sgT)
Usually, but it's easy to make sure. All three sensors should have about the same resistance.
Old Jan 17, 2003 | 04:24 PM
Default Re: HELP!!!!!!CEL #9 CYP Sensor (Chiovnidca)
ok, thanks
Holistic28
Honda CR-V & Element
Apr 4, 2011 09:52 AM
Blackcat_78
Jul 6, 2006 03:43 PM
quik89
Nov 30, 2003 06:43 PM
TurboLsVtec
Dec 9, 2001 05:04 PM
