K&N Oil Filter- Good?Bad?
Old Jan 17, 2003 | 09:27 AM
electrosi's Avatar
Default K&N Oil Filter- Good?Bad?
Just wondering if this filter was anygood. I have a Fram right now and want to switch over to a K&N gold oil filter. Tell what you know or what facts you've heard.
Thanks
Old Jan 17, 2003 | 09:34 AM
psion128x's Avatar
Default Re: K&N Oil Filter- Good?Bad? (electrosi)
As far I know, K&N makes excellent products. As for how much of a performance difference there is between the Fram and the K&N I dunno... I have a K&N racing air filter and my car is good with that. I can't really say how much better K&N is vs the Fram...but will just say that the K&N is better...
Old Jan 17, 2003 | 10:43 AM
Tweakmeister's Avatar
Fram filters are about as bad as you can get.
The K&N is one of the better ones out there, although a bit on the pricey side.
There have been several discussions, as well as used filter cut-ups on this before. If you don't mind paying for the K&N then go for it
Old Jan 17, 2003 | 11:20 AM
Nameless RB26's Avatar
Default Re: K&N Oil Filter- Good?Bad? (Tweakmeister)
K&N are good IMO. That's what I use..
Old Jan 17, 2003 | 04:35 PM
integra6650's Avatar
Default Re: K&N Oil Filter- Good?Bad? (Nameless)
mobil 1 is more trusted and performs better from my experience and what ive heard
Old Jan 17, 2003 | 04:49 PM
ejprimo's Avatar
Default Re: K&N Oil Filter- Good?Bad? (integra6650)
both mobil 1 and k&n oil filters are made by champion labs.
Old Jan 17, 2003 | 04:54 PM
Default Re: K&N Oil Filter- Good?Bad? (ejprimo)
i like them better so ha
Old Jan 17, 2003 | 08:55 PM
KingDsi's Avatar
Good job ejprimo! They are basically the same. I have only used either since I've owned the car. THEY ARE THE BEST YOU CAN USE, HANDS DOWN!
They are rated the best filtering efficiency after MULTIPLE passes. Fram is one of the worst.
HOWEVER, it has been said numerous times before...
"Change your oil at it's required intervals based on driving habits, and it will be the best life extending maintainance performed" (over putting the best oil and filter on your car, and not changing it soon enough)
Old Jan 18, 2003 | 07:26 AM
1RMDave's Avatar
Default Re: K&N Oil Filter- Good?Bad? (KingDsi)
I prefer to use only OEM Honda filters. But thats just my preferance(sp?) i guess.
Old Jan 18, 2003 | 12:38 PM
ejprimo's Avatar
Default Re: K&N Oil Filter- Good?Bad? (1RMDave)
there is a chance that you might be getting a fram filter when you go oem. if it is made in canada, then it is a fram filter. if it is made in america, then it is a filtech filter. heres a website that may help you choose another filter.
http://www.ntpog.org/reviews/filters/filters.shtml
let it be known that honda is cutting corners contracting fram to make oem filters.
personally i use bosch premium filters which is also made by champion labs. the difference b/w the stp, bosch premium, and mobil one is the filtering ability of each filter. the stp filter is rated at 20 microns whereas bosch premium is 15 microns and mobil one is 10 microns. i use bosch premium over mobil one b/c although the mobil oil filter has the highest filtering rating, it may be too restrictive in terms of oil flow ability. imagine sticking a large amount of filter media into a canister. on the one hand, it will do a great job in filtering your oil, but on the other hand, the oil cannot flow freely. i believe the filtering ability is just as important as oil flow ability. when the amount of oil being pumped into the oil filter surpasses the flow rate of the filter, then the oil filter goes into bypass mode which essentially means that oil is circulating throughout the motor w/o being filtered.
[Modified by ejprimo, 1:47 PM 1/18/2003]
Old Jan 18, 2003 | 01:36 PM
Goldfingiz's Avatar
OEM/Hamp!
Goldfingiz
Old Jan 18, 2003 | 08:39 PM
Quick 200k Mile Motor's Avatar
Default Re: K&N Oil Filter- Good?Bad? (Goldfingiz)
For the price, Purolator has the best filter media but does not flow near the K&N or the bad filtering Mobil1.
tempsohc
356
Apr 8, 2010 02:35 PM
vietnameeh
Northern California (Sales)
May 6, 2009 10:36 PM
JDMCRX
Jul 27, 2006 09:35 AM
EJK20R
Jul 31, 2005 09:09 PM
VTC_CiViC
Apr 24, 2002 09:46 PM
