car wont start. need help here.
Old Jan 17, 2003 | 02:08 AM
Frankie324's Avatar
Default car wont start. need help here.
I have a 92 Civic CX 1.5 that will not start and when is on has a bad speed sensor.
The starter and the speed sensor has been replaced and still same problem. The only way the car starts if its push started. The starter has constant power and ground going to it....... any ideas?? fuses are good, i already checked.
Anything I'm missing here??
Old Jan 17, 2003 | 06:11 AM
apalma0609's Avatar
Default Re: car wont start. need help here. (Frankie324)
Pull one of the spark plug wire from the car and connect a spark plug on it, crank the car and check for sparks, if there are non then it's your ignitor. Make sure you don't tough the spark plug while your cranking the engine.
Tad
Sep 5, 2007 09:51 PM
92cxcivic
Jul 2, 2007 06:38 PM
fwdftw
52
Sep 5, 2006 11:31 PM
98gsrTEG
Aug 1, 2005 06:30 PM
EVO_S4
Oct 11, 2002 02:46 PM
