Mines ECU - where to purchase? (did search)
Since I decided to leave my replacement engine stock, I`m looking for an aftermarket ECU. A while ago somebody recommended "Mines".
Does somebody know numbers and where to purchase ?
I know their website http://www.mines-world.com but I can`t find numbers for the DC2 there...
If someone knows another ecu to choose, this is the No. of my stock ECU:
37820-P73-G01 / 1117-101787 CHW
I want a redline not higher than 9100rpm.
What's your setup? What do you want to run? I can convert and re-program ECUs for different applications. OBD0-OBD1.
I tested a spoon ECU on a stock R last year and the difference was HUGE to the stock ECU. But spoon`s redline is too high (9500).
Okay, this is what it`s at:
On my favourite track there are some curves with shorter straights between. I need some raised rev limit to stay in 3rd in a few situations... With stock redline I only have two options:
1) shifting to 4th for 0,5sec
2) lifting acc.pedal
tooSo the main idea is a redline of 9000 or 9100 and an optimized f/a ratio and ignition timing of course... Vtec crossover doesn`t matter, I`m at 8k+ all the time.
Click on this link
http://www.perfectrun.com.au/perform...putervxrom.htm
why not call up kenji and get one of his ecus? I have one and I love the extra revs i get out of it. plus it cost less than some of the above mentioned.
Okay, who is Kenji and what are the numbers ?
The Ecu I have is for the 97-99 North American ITR. Straight plug and play. RPM is limited to 9200 and the VTEC cross over is at 5200rpm. Idles great at 900rpm.
My car:
1998 ITR euro (JDM spec). The longblock is a 1996 JDM spec (replacement engine).
Motor is stock, compression is JDM,
Our fuel is shell-optimax (99octane).
Relevant mods:
Comptech Icebox, 72mm throttle-body, JDM 4-1 header, 100cell racecat, 63,5mm stainless steel catback.
I have been selling Mines ECU while back. Here are the specs for the ECU.
-stock Vtec point
-adjusted fuel/ignition curve/rev limiter 9000rpm
-eliminated secondary O2 sensor
If you need more info you can email me.
[Modified by AJ PwR, 8:13 PM 1/19/2003]
-stock Vtec point
91efbluehatch
Nov 12, 2011 04:47 PM
RACEPAK
Aug 2, 2006 09:16 AM
granracing
Apr 23, 2004 12:53 PM
thanks b2
