How have you improved your gas milage? Please respond here --->
Old Jan 16, 2003 | 10:29 PM
sirminder's Avatar
Default How have you improved your gas milage? Please respond here --->
I would like to know on what some of you have done to improve your gas milage. I have an B16a with i/h/e, spoon ecu and lately I've been getting 250 on a full tank, sometimes as low as 225 . I just did an oil change (every 2000-2500 miles) and used an STP cleaner, but i did not notice and improvement.
I will be looking forward to change out the plugs, wires, cap and rotor. I currently have bosh platinum 4's, stock wires and I believe stock cap and rotor still (did the swap in june). But can someone please help me on the spark plugs and wires to get? I would like to get some NGK's but im not sure which ones to go with. I do a lot of rush hour traffic thru downtown L.A.
Thanks everyone.
Old Jan 16, 2003 | 11:03 PM
Kamin's Avatar
Default Re: How have you improved your gas milage? Please respond here ---> (sirminder)
its the spoon ecu.
run a stock b16 ecu and it will go up to about 25-30mpg.
Old Jan 17, 2003 | 03:31 AM
Albino Dragon's Avatar
Default Re: How have you improved your gas milage? Please respond here ---> (Kamin)
Stay out of VTEC and make sure that you have the correct amount of air pressure in your tires.
Old Jan 17, 2003 | 01:47 PM
sirminder's Avatar
Default Re: How have you improved your gas milage? Please respond here ---> (Albino Dragon)
Would using a VAFC to lean out help me a bit? I've been thinking of using an
Apexi vafc.
Old Jan 17, 2003 | 04:27 PM
integra6650's Avatar
strip out the rear and use higher octane
Old Jan 17, 2003 | 08:28 PM
jweller's Avatar
Default Re: How have you improved your gas milage? Please respond here ---> (integra6650)
get the lead taken out of your right foot
increase tire air pressure
Old Jan 17, 2003 | 10:27 PM
icelarry27's Avatar
Default Re: How have you improved your gas milage? Please respond here ---> (jweller)
easiest way: don't drive, your tank will last for WEEKS....heh
Old Jul 11, 2003 | 06:33 AM
professorman's Avatar
Default Re: How have you improved your gas milage? Please respond here ---> (icelarry27)
what are some of the things that can be changed to inprove gas milage? i have 92,000 miles on my car now
Old Jul 11, 2003 | 07:27 AM
Daemione's Avatar
Default Re: How have you improved your gas milage? Please respond here ---> (profroopchan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by profroopchan &raquo;</TD></TR><TR><TD CLASS="quote">what are some of the things that can be changed to inprove gas milage? i have 92,000 miles on my car now</TD></TR></TABLE>
Tough to answer without knowing anything about what you've done with your car.
Most maintenance items will affect mpg, some more quickly & severely than others. Air filter, spark plugs, wires, cap, rotor, 02 sensor(s), valve adjustment, tire pressures . . . .
Actual modifications that will improve fuel mileage would be any improvement in exhaust flow, weight reduction, narrower/harder tires, more rotational inertia (wheels/tires/flywheel/brakes/etc.) if you're all highway, less if it's transient stop & go driving. A programmable ECU can be used to either help fuel mileage or hurt it. Higher octane fuel can either hurt or help your fuel mileage, it depends on the car & ECU. A synthetic or lighter weight motor & tranny oil can sometimes help marginally. Port-matching will help, more comprehensive headwork can sometimes help, but just as easily hurt.
Old Jul 11, 2003 | 08:26 AM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">get the lead taken out of your right foot
increase tire air pressure</TD></TR></TABLE>
LOL
lil_wilde
Nov 2, 2009 08:33 PM
jb.
Nov 30, 2006 01:36 PM
gimme_h22
Oct 10, 2004 02:58 PM
aznmc16
Jul 5, 2002 01:12 AM
thashadow
Jun 22, 2002 05:39 PM
