ls and gsr oil pan??
Old Jan 16, 2003 | 09:43 PM
DD_JonnyLee's Avatar
Default ls and gsr oil pan??
will a LS oil pan fit a gsr??? im taking off my turbo and putting it in my ls/crx and was wondering if it could just switch oil pans??
tia
jonathan
Old Jan 16, 2003 | 09:48 PM
Suprdave's Avatar
Default Re: ls and gsr oil pan?? (JonathanH)
Oil Pickups are different, yo...
Suprdave
Old Jan 16, 2003 | 11:07 PM
Default Re: ls and gsr oil pan?? (Suprdave)
so i have to have my oile return line removed and put my gsr pan back on....................................damn it, loaning parts from my daily driver to my project car has started to be a pain in the azzzzz
Old Jan 17, 2003 | 02:54 AM
turbohonda's Avatar
The only way to determine what pan and pickup to use on a B-series block is to look at what main caps you use. If you use the stock LS main caps then the only pickup and pan that you can use is the LS (possibly the B16A pan and pickup as well since it doesn't have a girdle either). However, if you use the Gsr girdle on the LS main caps then you will need the GSR pickup and pan. Make sure you never mix and match the pick ups and pans.
[Modified by turbohonda, 3:55 AM 1/17/2003]
93egSLEEPER
Sep 27, 2009 07:05 PM
esoterEK..
Feb 22, 2007 09:36 PM
Turbotype
Feb 21, 2005 11:15 AM
nevin
Dec 23, 2004 05:57 PM
filetofit
May 2, 2002 05:15 PM
