Top speed probīs with civic ee9 (b16a1)
Old Jan 16, 2003 | 09:39 PM
german_vtec's Avatar
Default Top speed probīs with civic ee9 (b16a1)
Hi
when my car was stock top speed was 235km/h (about 147mph)
now i have a ventuli plate, an Fujitsubo tail silencer, an TeZet Header and
and ecu is chip-tuned.
Now my top speed is only 220km/h(138mph)
Has anyone an idea what my problem is ? I think its the ventuli plate and/or
the ecu tuning - but i want to know it before im going to remove the ventuli plate...
Further only with sinlencer, - top speed was 235km/h
and iīve got about 170hp (150hp is stock)
im going to to another mesurement on the dyno and see what i have now...
If you donīt know this car, itīs an 91ī civic hb with the B16a engine - only sold in germany, it should be very similar to the EF9...
it would be graet if anyone could give me usefull tips
greets from germany
Stefan
Old Jan 16, 2003 | 09:45 PM
Cashflo's Avatar
Default Re: Top speed probīs with civic ee9 (german_vtec)
sorry cant help, got pics of ee9 though?
Old Jan 17, 2003 | 01:18 AM
madslackin's Avatar
I'm not a big top-speed freak, but that ventuli plate you have was not made for high-end power. The idea behind it is to speed up air into the combustion chamber by making the ports smaller. This increases mid-range power but limits high rpm power to some degree. I'd be willing to bet that removing that ventuli plate would increase your top speed.
Justin
Old Jan 17, 2003 | 02:13 AM
texan's Avatar
Default Re: Top speed probīs with civic ee9 (madslackin)
10 mph is a pretty big hit for just a bit of increased port speed, I'd be more inclined to think it's either the ECU tune or something else.
Old Jan 17, 2003 | 03:05 AM
HookUpsImportTek's Avatar
Default Re: Top speed probīs with civic ee9 (texan)
Actually, the ventulli is most likely the problem. They do cause quite a bit of restriction at those rates of intake. Just a though. -HIT
[Modified by HookUpsImportTek, 4:05 AM 1/17/2003]
Old Jan 17, 2003 | 06:01 AM
Default Re: Top speed probīs with civic ee9 (HookUpsImportTek)
Thanks a lot for all the fast answers -
iīll do some test driving with stock ecu and if itīs not better iīll going to remove the ventuli plate but itīs a lot of work and iīll lose mid-range power - but it should run at least stock top speed
Today i was on the dyno, but my header is to low so i canīt do another dyno run
maybe iīll search another dyno...
Iīll post again on sunday after the tests and let you know
then iīll post some pictures too!
Stefan
Old Jan 19, 2003 | 02:08 PM
HI
after several hours, over 500km on the "Autobahn", and removing the tuned ecu
top speed is sitll only a bit over 220km/h(138mph)
iīm now going to remove my ventulil, but i donīt know when i aill have the time to do this - iīll let u know...
Stefan
darthure
37
Jun 1, 2023 12:54 PM
fryman
Sep 20, 2009 11:04 AM
specm24
Oct 10, 2003 09:26 AM
02blakeLX
12
Oct 18, 2002 04:51 AM
