changed belts, now engine has buzzy vibration
Old Jan 16, 2003 | 08:24 PM
jdowen2's Avatar
Default changed belts, now engine has buzzy vibration
I replaced a leaking waterpump as well as the drive belt and balance shaft belt. I was careful to get everything lined up to top dead center when I put everything back together. Now the engine vibrates or buzzes at low rpm's. All nuts and bolts were accounted for. Now what?
Old Jan 16, 2003 | 08:43 PM
Razor's Avatar
Default Re: changed belts, now engine has buzzy vibration (jdowen2)
make sure all bolts are torqued down to spec, if they're lose it will vibrate
Old Jan 17, 2003 | 07:08 AM
jweller's Avatar
Default Re: changed belts, now engine has buzzy vibration (Razor)
are you certain the balancer belt is on correctly. if the crank wasn't at TDC when you set the balancer shafts you could have the belt on right, but the balbancers are out of sync with the motor
Nathan007
Nov 28, 2010 12:12 PM
Angel_prelude
May 20, 2008 09:05 PM
jetlude
Oct 9, 2005 09:02 PM
AMG
Sep 3, 2004 10:09 AM
pbizzlegsr
Jul 7, 2004 07:48 AM
