Tranny need to be flushed?
Old Jan 16, 2003 | 04:12 PM
tylerdurden's Avatar
Default Tranny need to be flushed?
Does a manual tranny need to be flushed like an automatic to get the dirty fluid out or do you just drain the pan? I won't bother draining the pan if it doesn't do that much good anyway.
Old Jan 16, 2003 | 04:22 PM
90da's Avatar
Default Re: Tranny need to be flushed? (tylerdurden)
There should be a drain plug that you take out on the bottom, I think......
I know there is one on the side to get the fluid back in.
Old Jan 16, 2003 | 04:29 PM
Flexmyrex's Avatar
Default Re: Tranny need to be flushed? (90ef)
yep
drain plug is right under the axle, (1/4 driver correct me if im wrong).
refill plug is next to the axle (17mm)
Old Jan 16, 2003 | 04:30 PM
I know about that, I was just wondering if you need to have a manual tranny flushed (like you do with an auto tranny) to get all the old fluid out. If you don't flush an auto tranny most of the dirty oil stays in there. I don't want to leave all that dirty oil in there.
Old Jan 16, 2003 | 04:36 PM
Patch's Avatar
You don't need to flush a manual tranny. If you really want to get it clean, take the drain and fill plug out and just pour some fluid through it to get the crap out. That's about as clean as its gonna get while its still bolted to your engine. Don't forget to check your drain plug magnet for metal, if theres a lot, consider getting it checked out...
Old Jan 16, 2003 | 04:45 PM
Default Re: Tranny need to be flushed? (pat86)
Ok, thanks, that's what I needed to know.
Old Jan 16, 2003 | 04:54 PM
BTW, how much fluid will I need to refill the tranny and does anyone know anyplace online to get Honda MTF?
Old Jan 16, 2003 | 05:02 PM
90da's Avatar
I think it's 2.5L. Your best bet is to fill it up to the bottom of the fill hole on the side.
Check http://tech.hybridgarage.com/tech/index.html go to the 88-91 civic/crx service manual link and look under specs.(?)
Old Jan 17, 2003 | 05:57 AM
Patch's Avatar
Just fill it up until fluid starts to run out of the fill plug, then put it back it, tighten it up and away you go.
Old Jan 17, 2003 | 06:22 AM
Ef Whore's Avatar
the higher u jack the pass. side up --the more fluid u can get in there.
Old Jan 17, 2003 | 09:00 AM
rioninja's Avatar
B-series trannys have a pretty decent magnet on the inside bottom of the casing, which catches most of the metal debree.
Old Jan 17, 2003 | 10:34 AM
PhatOptimo's Avatar
Default Re: Tranny need to be flushed? (RioNinja)
Yes, and the d-series does 2. The drain plug is made for a 3/8 drive wrachet FYI.
[Modified by Phat_Optimo, 1:35 PM 1/17/2003]
Old Jan 17, 2003 | 10:46 AM
keithv's Avatar
Default Re: Tranny need to be flushed? (Phat_Optimo)
make sure the car is level when you fill the tranny as well.
sublimeh215
11
May 7, 2009 07:05 AM
AR-cb7
Apr 8, 2008 09:27 AM
CBR600OnTop
Dec 30, 2002 05:04 AM
pelotudo
Jul 21, 2002 02:33 AM
96Prelord
Jun 5, 2002 07:21 PM
