Heater Problems........HELP!
Old Jan 16, 2003 | 04:12 PM
eg94b18's Avatar
Default Please Help I'm Cold(Heater Question)!!!!!
Alright..... I have replaced the thermostat and still no heat.Air blows out fine but it is not warm(yes the climate lever is on heat).Both hoses to and from the radiator are flowing hot.What could be stopping it from blowing heat into the car? TIA
[Modified by eg94b18, 8:28 PM 1/16/2003]
[Modified by eg94b18, 8:32 PM 1/16/2003]
Old Jan 16, 2003 | 04:33 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Please Help I'm Cold(Heater Question)!!!!! (eg94b18)
your heater core may be damaged, your tubes may be bypassing the heater core altogether, your switch may be broken, maybe a bad connection...lots of options.
Old Jan 16, 2003 | 04:35 PM
eg94b18's Avatar
Default Re: Please Help I'm Cold(Heater Question)!!!!! (Archidictus)
btw its on a 98 civic ex.......can the core already be bad?
Old Jan 16, 2003 | 05:07 PM
civura R's Avatar
theres a air bubble most like purge the hoses
Old Jan 16, 2003 | 05:20 PM
IM ALL BOB's Avatar
check I believe the heater valve .. basically there's a wire connected to the Climate control lever that goes left to right..and I noticed that somehow mine was bent .. (for the love of god I can not explain this..if only I can show u itd be much easier) but mine was bent and I had to manually open the valve .. voila.. heat.. and if I want my AC to work I just manually move it back I need to get it replaced though but I'm to lazy oh yeah i drive a 98 dx
[Modified by IM ALL BOB, 6:20 PM 1/16/2003]
Old Jan 16, 2003 | 05:28 PM
slomofo's Avatar
GDD Member
Default Re: Please Help I'm Cold(Heater Question)!!!!! (IM ALL BOB)
I was thinking the same thing, since my friend has had this problem.
If it still not blowing out hot air, then take off the heater hoses, and put a hose to it to see if any water flows through the heater core. If it does not, then you have your heater core is not flowing properly and is most likely bad.
Old Jan 18, 2003 | 09:32 PM
eg94b18's Avatar
Default Re: Please Help I'm Cold(Heater Question)!!!!! (slomofo)
thanks guys i will try all of the above mentioned
playertwo
Dec 13, 2011 02:36 PM
curtie94
Mar 18, 2011 07:42 PM
ComicConBooBoo
13
Jan 2, 2011 07:01 AM
BlackSheep209
11
Dec 23, 2006 09:38 PM
jadugartir
12
Nov 10, 2006 10:18 AM
