people with b16a's I need your help...
Old Jan 16, 2003 | 01:32 PM
MeanGreenEG9's Avatar
Default people with b16a's I need your help...
Can someone do me a favor? Check the oil pressure sensor unit thats to the left of the oil filter on your block.. can you check and see if yours is bolted all the way down? As in can you see any threads left over between the sensor and the block? I hope this isn't too conffusing.. Reason I ask is I think oil is leaking out of the sensor becuase its not bolted all the way down but I can't seem to be able to turn it anymore than it already is.... so i'm not sure if this is normal or not.. Thanks for whoever wants to help
[Modified by SlowAssB16a, 2:33 PM 1/16/2003]
Old Jan 16, 2003 | 04:00 PM
Default Re: people with b16a's I need your help... (SlowAssB16a)
no one wants to help me out???
Old Jan 16, 2003 | 04:21 PM
10K2HVN's Avatar
i would help you but i only have the top half of the B16...
Old Jan 16, 2003 | 04:41 PM
advanracing62's Avatar
Default Re: people with b16a's I need your help... (10K2HVN)
It looks to me that the sensor is very close to the block. I don't see any threads, I'll get under the car and take a look later tonight.
Old Jan 16, 2003 | 04:48 PM
Default Re: people with b16a's I need your help... (advanracing62)
Thanks bro.. yeah its hard to tell from the top but i didn't want to ask anyone to go underneath the car since it would be too much of a hassle.. thanks to anyone who can help though...
Old Jan 16, 2003 | 07:04 PM
mmuller's Avatar
Mad Scientist
ok i just checked and no its not all the way in; i see threads and there is a 5mm space between the sensor and block.
ope this helps
peace
Old Jan 16, 2003 | 10:08 PM
Default Re: people with b16a's I need your help... (mmuller)
ope this helps
peace
looks that way to me as well. You might want to pull the sensor and slap some Hondabond on the threads... that will seal her up good n tight!
[Modified by advanracing62, 12:09 AM 1/17/2003]
Old Jan 17, 2003 | 12:00 AM
BluntMan's Avatar
wrap it in teflon tape. then it wont leak!
Old Jan 17, 2003 | 05:31 AM
RCautoworks's Avatar
Default Re: people with b16a's I need your help... (BluntMan)
Here is mine
I am pretty sure mine is threaded all the way on.
[Modified by 90blackcrx, 8:32 AM 1/17/2003]
Old Jan 17, 2003 | 02:25 PM
wrap it in teflon tape. then it wont leak!Can someone do me a favor? Check the oil pressure sensor unit thats to the left of the oil filter on your block.. can you check and see if yours is bolted all the way down? As in can you see any threads left over between the sensor and the block? I hope this isn't too conffusing.. Reason I ask is I think oil is leaking out of the sensor becuase its not bolted all the way down but I can't seem to be able to turn it anymore than it already is.... so i'm not sure if this is normal or not.. Thanks for whoever wants to help
Teflon tape? Are you saying wrap the threads in teflon tape and bolt it back in? How will it bolt back in if the threads are covered? what about high temp rtv? would that work just as well?
Old Jan 17, 2003 | 02:30 PM
Blaze45's Avatar
Brrraaaap!
yeah high temp rvt will work.
Blaze
Old Jan 17, 2003 | 02:44 PM
Default Re: people with b16a's I need your help... (Blaze45)
Blaze
Word.. i'll try that this weekend and let ya'll know. Good lookin out
Old Jan 17, 2003 | 02:46 PM
pr0jektdc2's Avatar
hey ould u happen to tell me the sie soket you are using to take it out?!?!? thanks!!!!!
Old Jan 17, 2003 | 03:18 PM
Default Re: people with b16a's I need your help... (pr0jektdc2)
i haven't taken it out yet but i beileve its a 15/16
Old Jan 17, 2003 | 06:41 PM
pr0jektdc2's Avatar
i think u may be wrpng...i believe its in the deepsocket 20-23 mm range...
Old Jan 17, 2003 | 07:37 PM
mmuller's Avatar
Mad Scientist
Im pretty sure is a 25mm, but if you dont have it use 15/16 it works just fine.
Old Jan 18, 2003 | 05:44 PM
I am POSITIVE now that the leak is comming out of the oil pressure sensor.. I used a small mirror to see through the small spot.. now the problem is i used high temp RTV on the threads and then rebolted it on the block but it STILL leaks! not any slower either.. should i just get a new sensor? i dont see anything visually wrong with the one i got
Old Jan 18, 2003 | 06:04 PM
B18EG6's Avatar
24MM!
Old Jan 18, 2003 | 06:50 PM
irev210's Avatar
Default Re: people with b16a's I need your help... (B18EG6)
pull it
clean the threads
use teflon tape
Old Jan 18, 2003 | 07:58 PM
IN VTEC's Avatar
Teflon tape is really thin and malleable, so it's able to conform to whatever small space, depending on how much you put on.
Wrap it twice around.
The RTV may not have sealed completely around the threads. The oil makes it harder for it to seal the block b/c it won't bond/stick to oil.
Old Jan 19, 2003 | 01:41 PM
Default Re: people with b16a's I need your help... (IN VTEC)
Teflon worked.. can't believe all this time the solution was a 99 cent roll of tape! Thanks ya'll
Old Jan 21, 2003 | 09:47 PM
BluntMan's Avatar
told you to use teflon. when use used rtv, did you wait a while for it to cure?
Old Jan 22, 2003 | 11:07 AM
Nah i didn't wait for it to cure.. probably why it didn't work right?
krysted9354
Dec 28, 2008 12:43 PM
joedr
Nov 9, 2008 12:11 PM
BlUAc
Jan 27, 2006 06:39 AM
oemDC2
Apr 28, 2004 09:37 PM
oemDC2
Apr 28, 2004 09:19 PM
