Old Mar 25, 2015, 09:56 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Intake Resonator Removal?
Old Jan 16, 2003 | 11:58 AM
pyrojeff's Avatar
Default Intake Resonator Removal?
Has anyone here taken out the intake resonator located below the air box (at least on my '94 LX)? I hear it gives the intake better access to air, and slightly helps performance. So is it worth the effort, and if so, are there any instructions online describing how to remove it?
Old Jan 16, 2003 | 12:04 PM
ArchAngel Sabastian's Avatar
New User
Default Re: Intake Resonator Removal? (pyrojeff)
take out your inner fenerwell on the pass side and take out the bolts holding it on there 2 or 3 then get to yankin it out.
Old Jan 16, 2003 | 12:05 PM
pyrojeff's Avatar
Default Re: Intake Resonator Removal? (ArchAngel Sabastian)
Thanks for such a fast response. Do I need to take off the wheel in order to do this? And does it help the air intake by removing this?
Old Jan 16, 2003 | 12:24 PM
johnsaccord's Avatar
You can keep the wheel on, if your lowered you may need to turn the wheel or jack it up a little so you can reach all the fender liner screws. Yes, it does help get air to the intake better, because you will now have a hole that goes right into the engine bay under the intake.
Old Jan 16, 2003 | 07:33 PM
pyrojeff's Avatar
Default Re: Intake Resonator Removal? (johnsaccord)
Alright cool, thanks for the information... I'll have to try this tomorrow during the daytime...
Old Jan 16, 2003 | 07:40 PM
greensleeper's Avatar
yeah just like he says. I think its four bolts. and then you just fenagle it out.
sounds better. drives better. and at the least you can consider it weight reduction.
Old Jan 16, 2003 | 08:45 PM
Razor's Avatar
Default Re: Intake Resonator Removal? (greensleeper)
take off the resonator and put in a drop in k&n air filter and you're set, you have a good intake system w/o the risk of hydrolocking(if u had a CAI)
Old Jan 17, 2003 | 12:15 PM
TheOnlyChrisB's Avatar
I took mine off when I did my Black housing headlights, I had to take the bumper off, and there it was, so I removed it. Easy, I think it was 4 bolts???
Old Jan 17, 2003 | 05:52 PM
Razor's Avatar
Default Re: Intake Resonator Removal? (TheOnlyChrisB)
yeah something like it, its the big black box right under your intake filter housing.
Old Jan 17, 2003 | 06:44 PM
One2chi's Avatar
Default Re: Intake Resonator Removal? (Razor)
if you want, you cna rip out the whoel air box and resonator, and just get a cone air filter, and put it at the end of your intake....works wonders.
Old Jan 17, 2003 | 07:40 PM
pyrojeff's Avatar
Default Re: Intake Resonator Removal? (5thgenaccordian)
Yeah, got it removed...took a little more work than I thought it would've taken, because I wasnt able to take the resonator thru the wheel well, and instead took it out by removing the part of the inner wheel fender that goes underneath the car. But anyways, its out.
I've had a K&N filter in my car a while, but it doesn't reach all the way over to where the stock airbox was. I'm just trying to decide whether extending the hose would be to my benefit or disadvantage, because making air travel longer makes it slower i guess.
Thanks for the help.
dbobby2b
Aug 23, 2008 11:10 PM
EcHoB18C1
Jun 4, 2008 12:34 AM
00siandrew
Aug 20, 2006 07:30 PM
civic_on_13s
Jul 28, 2003 05:25 PM
WaterDrake
Nov 6, 2001 06:48 AM
