Ole crazy crackhead idle
Old Jan 16, 2003 | 11:29 AM
maxpsi's Avatar
Default Ole crazy crackhead idle
ok.........on cold starts my car idles up close or a little past 2k rpm. When the car warms up, it still idles the same. When I drive my car for a little it still idles the same. The only way I can get a decent idle is to wait till the car is warm and reset the ECU. There are no CELs or stuttering (car runs fine) since I recently replaced my TPS. Help, please???
Old Jan 16, 2003 | 11:37 AM
Shawn C's Avatar
In The Garage
Default Re: Ole crazy crackhead idle (maxpsi)
its probably a vaccuum leak, possibly in one of the manifold sensors/valves. do a search for fluctuating idle or irratic idle
Old Jan 16, 2003 | 11:42 AM
maxpsi's Avatar
Default Re: Ole crazy crackhead idle (22lbGS-R)
But if it was a vacuum leak, then shouldn't it stay high even if I reset the ECU. See it has to be some sort of sensor giving a bad reading or something electrical, because it is fixed when I reset the ECU. But I am not getting any CELs.
Old Jan 16, 2003 | 12:34 PM
Shawn C's Avatar
In The Garage
try this..... disconnect the Throttle Positioning Sensor (TPS) and run it. if it idles normal, it could be that
ok i just read the thing about you replacing the TPS. why did you replace it? what was it doing?
[Modified by 22lbGS-R, 9:36 PM 1/16/2003]
Old Jan 16, 2003 | 12:42 PM
maxpsi's Avatar
I am going to try diconnecting the TPS like you said. Maybe replace the FITV also.
http://forums.clubsi.com/showflat.ph...ue#Post1450375
Old Jan 16, 2003 | 12:51 PM
maxpsi's Avatar
Unhooked the TPS. Got a CEL. Guess which one. CEL 14. Nothing changed. Still idles high. I believe it might me the FITV, but wouldn't it throw a code since it is a sensor. If it was the FITV, that would make since since I have to reset the ECU. UGH! lol
zach1288
Jun 12, 2010 04:32 PM
traxxasx
Oct 11, 2007 12:50 PM
1990si
Dec 11, 2006 10:01 AM
