problem installing b16
Old Jan 16, 2003 | 08:43 AM
roninb18's Avatar
Default problem installing b16
We're installing a b16a2 into my friends eg civic cx hatch. It idles fine when still cold but as soon as it warms up it is irregular. It's like it revs and comes back down and revs again and then shuts off. The ecu is showing a problem with the map sensor. We checked everything there and still can't find a problem. Any ideas on what it could be?
Old Jan 16, 2003 | 08:49 AM
Spade's Avatar
Default Re: problem installing b16 (roninb18)
First unplug the IACV and see if the problem goes away.
Then, Check all vaccum lines.
Next, reset ECU and allow car to "learn" for 10 minutes minimum.....in other words, start it and leave it alone for 10 mins.
Old Jan 16, 2003 | 08:56 AM
slomofo's Avatar
GDD Member
Did you accidentally mix up the plugs for the MAP and TPS sensor.
Old Jan 16, 2003 | 08:58 AM
d15dood's Avatar
most likely a vacumm problem, make sure you connected all the hoses
Old Jan 16, 2003 | 09:04 AM
roninb18's Avatar
none of these solve the problem. any other ideas?
Old Jan 16, 2003 | 09:18 AM
slomofo's Avatar
GDD Member
I have the same problem with my car, it's my MAP sensor, but honda wants like $400.00 for a new map sensor so I'll just live the rest of my days with a bad map sensor unless I can find one in a junkyard. Hey, do you have the stock map sensor in your old motor? If so, i'll buy it off of you.
[Modified by slomofo, 6:19 PM 1/16/2003]
Old Jan 16, 2003 | 09:32 AM
fire7882's Avatar
Default Re: problem installing b16 (slomofo)
I had a reving problem with my b16. When it got warm, it would rev from 800 to 1100 rpms. I wasn't throwing a code and it took me forever to figure out the problem. Turns out the engine wasn't grounded enough to the car. Just a sudgestion.
Old Jan 16, 2003 | 10:30 AM
ejprimo's Avatar
Default Re: problem installing b16 (fire7882)
use can use the d-series map sensor for your b-series.
xASAPx
Sep 15, 2006 09:21 PM
cbrodac0424
Apr 27, 2006 10:37 AM
florinels
Jan 24, 2004 07:10 PM
