Need SPECS to my B16 (ordering custom Pistons)
Old Jan 16, 2003 | 07:24 AM
Mr. Vapor's Avatar
Default Need SPECS to my B16 (ordering custom Pistons)
i need the following specs for the b16!
Cubic Inch displacement: Im assuming 1600cc?
bore size: Stock is 81mm but im bored to 83mm
stroke: ?
Rod Length: ?
Rod Small end width: ?
thickness above pin: ?
block height: ? (its stock)
deck clearance: ? (Stock)
compression height? (If known)
head gasket thickness: ? (Stock thickness)
Camshaft specs:
Gross Valve Lift Intake: ?
Gross Valve Lift exhaust: ?
Lobe seperation (Degrees): ?
Degreed in Std Degree + : ?
Degreed in Std Degree - : ?
Duration @ .050 Intake: ?
Duration @ .050 exhaust: ?
Valve lift at TDC Intake: ?
Valve lift at TDC Exhuast: ?
Combustion Chamber size in CCs
Valive diameter Intake
valve diameter exhaust
again, if anyone can point me in the right direction, id be greatly indebted to you, any informatin will help very much.
Old Jan 16, 2003 | 08:03 AM
Spade's Avatar
Default Re: Need SPECS to my B16 (NYb16)
Damn you want a lot.....hold on.
Old Jan 16, 2003 | 08:15 AM
Spade's Avatar
Cubic Inch displacement: 1595cc
bore size: 83mm
stroke: 77mm
Rod Length: ?
thickness above pin: 21.0 mm
head gasket thickness: 0.029 inches
Combustion chamber volume: 42.70cc
Camshaft specs: I suggest you get the specs of a future cam you would like to use. They are asking for this information for valve relief that they will put in the piston.
EDIT: LOOKY what I found. http://raceseek.com/honda_specs.htm
[Modified by Spade, 9:16 AM 1/16/2003]
Old Jan 16, 2003 | 08:16 AM
Mr. Vapor's Avatar
Default Re: Need SPECS to my B16 (Spade)
well i plan to go with an OEM GSR Cam....... thanks for the help so far, you've always been a great help
Old Jan 16, 2003 | 08:17 AM
Spade's Avatar
NP...I edited so you can get some more.
Suggest ITR cams though.
Old Jan 16, 2003 | 08:59 AM
Benny Hinn's Avatar
If I were you, I would call their tech line.
More than likely, they have thwe specs that you need already.
Just tell them what block application, and that it is 83mm bore...
let us know what happens
Benny
Old Jan 16, 2003 | 12:09 PM
Kataku2K3's Avatar
Rod Length: ?
block height: ? (it's stock) 263mm's
deck clearance: ? (Stock) yup = 0.020"
compression height? (If known) you mean cc's of dome?? PR3 slugs have a 6.01cch's of dome... P30's have 0.92 over a PR3
Wasn't too much help here^^ hahaha oh well
GSR cams are better than B16 but i would still consider using a CTR/ITR IN and GSR/'R EX...
Here's the specs for the GSR's that you plan too use...
IN (1mm)
opens @ 10° before TDC
closes @ 40° after BDC
lift = 10.6 mm's
diameter = 33 mm's
duration = 230°
EX (1mm)
opens @ 40° before BDC
closes @ 7° after TDC
lift = 9.8mm's
diameter = 28 mm's
duration = 227°
An SiR1 would have the same numbers for the IN cam minus 0.5mm of lift, EX are the exact same...
THIS IS WHY SPADE and I WOULD RECOMMEND A CTR/2000+ITR intake cam and CTR/ITR exhaust cam over B16A (if you have a GSR exhaust cam then i wouldn't worry about gettin an R exhaust.. It's just not goin to do a whole hell of a lot over the GSR)
IN (1mm)
opens @ 18° before TDC
closes @ 45° after BDC
lift = 11.5 mm's
diameter = 33 mm's
duration = 243°
EX (1mm)
opens @ 45° before BDC
closes 10° after TDC
lift = 10.5 mm's
diameter = 28 mm's
duration = 235°
Good Luck
Old Jan 16, 2003 | 01:25 PM
Kataku2K3's Avatar
Default Re: Need SPECS to my B16 (Kataku2K3)
Also I was just wondering... What is soo special about this custom piston?? What brand?? If they already make pistons for VTEC motors (such as JE, etc.) then just have them use a VTEC setup and build the dome and valve reliefs to your specs unless you are modifyin the bottom side of the piston (the wrist pin, etc.) Peace
[Modified by Kataku2K3, 2:27 PM 1/16/2003]
Old Jan 16, 2003 | 04:40 PM
Deltax75's Avatar
[/QUOTE]
Not to stray to much off topic, your not the only person i've heard say GSR cams are better than a B16a's. I'm just curious how, I see your posted specs but here's to different sites that say they are exactly the same:
http://www.g-speed.com/pbh/b16a/
http://sales.hondatwincam.com/modelspecs.htm
BTW, there's specs for both JDM and USDM.
(I'm not looking for a fight, just clarification.)
Old Jan 16, 2003 | 06:47 PM
Kataku2K3's Avatar
Default Re: Need SPECS to my B16 (Deltax75)
Yea but they are, but as you can see in my post above i was refering the the SiR1 not the 5 million series... Peace
Old Jan 16, 2003 | 09:34 PM
10K2HVN's Avatar
ive been meaning to post earlier but...
All B-series engines have a 81mm bore..EXCEPT..! the B20....
as for rod specs.. this should help..
Pistons
[Modified by 10K2HVN, 10:38 PM 1/16/2003]
96halx
Jul 25, 2009 11:09 AM
hahaha38
Jun 23, 2007 01:53 PM
White Lightnin
Jul 23, 2004 06:06 AM
Mr. Vapor
Jan 16, 2003 10:11 AM
Evs-One
Jul 29, 2002 06:03 PM
