Do you maintain your maintenance free oem battery?
Old Jan 16, 2003 | 02:31 AM
kkim's Avatar
Default Do you maintain your maintenance free oem battery?
I know it says the battery that comes with our cars are maintenance free, but I wondered if you guys knew that you can service the battery in your cars like any other battery.
Under the plastic sticker/label on the top of your battery, there are screw caps for each of the wet cells. the plastic label is even perforated where you can remove this portion of the label, if desired. Once you remove the cap to each cell, you can see the water level in the there. I fill mine up with distilled water till it reaches the bottom of the plastic looking insert in there. (don't overfill)
I checked mine due to the high number of failed battery posts I've seen in the past. A battery is a battery and it needs the proper amount of water to operate properly. When I checked mine, the water level was very low.
Just thought I'd post this as I can imagine you guys on the mainland needing that extra cranking power for those cold mornings.
Better to check it now before it decides to fail on you at the worst possible time.
Old Jan 16, 2003 | 04:47 AM
Blue Liquid's Avatar
New User
Default Re: Do you maintain your maintenance free oem battery? (kkim)
Ah the irony of it...I just had to replace my 24 month factory battery after 25 months of use. It finally let go two weeks ago, on a cold 20 degree morning.
Old Jan 16, 2003 | 06:16 AM
yoshi234's Avatar
I shoot brides
Default Re: Do you maintain your maintenance free oem battery? (Blue Liquid)
24month factory battery?
yshi - who thought most were good for about 5yrs *shrugs*
Old Jan 16, 2003 | 06:29 AM
New User
Default Re: Do you maintain your maintenance free oem battery? (yoshi234)
I had presumed the same thing. I called Acura all irritatred because what I thought was a 5 year battery had died after only two years. That's when I found out it was only good for two. I wonder if it would have lasted longer had I maintained it? Oh well, I replaced it with a 6 year battery, last me the life of the car for sure. BTW, you will need what is called a 'reverse terminal battery' should you need to replace it in the future. I had a heck of a time finding it. Most batteries have the positive on the left, neg on the right, but ours are reverse. And you can't rotate the battery 180 degrees because then the battery cables aren't long enough to fit onto the terminals, which are now closer to the firewall than before.
Old Jan 16, 2003 | 12:37 PM
Dave-ROR's Avatar
I've been using the stock battery for almost three years (bought the car on march 10th 2000) without a problem.. and without any maintainance.. though my neg battery terminal wont tighten anymore.. I removed it once
Old Jan 16, 2003 | 12:42 PM
B2FiNiTY's Avatar
I never even touch mine.
Old Jan 16, 2003 | 12:46 PM
George H's Avatar
Default Re: Do you maintain your maintenance free oem battery? (B2FiNiTY)
Same here. I'm sure the problems will start with mine if I do touch it.
bike1962
Honda Fit
Dec 10, 2011 08:34 PM
eMpAtHy
Aug 7, 2010 03:28 PM
gsr.sedan
Feb 11, 2004 12:19 PM
ridiculous
Nov 13, 2002 11:52 AM
EGh22aEG
Apr 19, 2002 12:05 PM
